Not able to install successfully nvidia driver into my debian 12 desktop.
The compilation is failing.
I have checked, the gcc version is right in my setup.
Please help.
Attaching nvidia-bug-report.log.gz
nvidia-bug-report.log.gz (74.5 KB)
I just finished installing my driver for GeForce RTX 3060 Ventus 2x 12G OC on Debian 12 Bullseye. I got the driver from msi.com.
First, go to Synaptic Package Manager and update pkg-config to version 1.8.1 (the latest version that Synaptic has)
Next, you need your Linux driver file, which will look something like or exactly like mine:
NVIDIA-Linux-x86_64-535.54.03.run
Next, assuming you are at your terminal and in the same directory as the driver, enable it with:
sudo chmod +x name of the file for your driver
then, to install:
sudo ./name of the file for your driver
My desktop started out looking a bit like Windows 3.1. I restarted my computer; now the rendering looks fine.
I can build latest driver in Debian 12. Install most preffered building tools with āsudo apt install build-essentialā and try again.
Thanks a ton. I am now able to build and install the latest driver. Its totally worked after installing the build-essential.
Add to /etc/modprobe.d/nvidia-drm-modeset.conf
options nvidia-drm modeset=1
This will help you
hello. I am starting to use debian for the first time. I have tried to install Nvidia geforce rtx 3060 driver. there is always an error. when i reboot debian i get the following screen and i canāt continue. I have to reinstall everything. please I need help. Lenovo Legion 5 15ACH6H Ryzen 7 16GB 1TB SSD GeForce RTX 3060 6GB 15.6"
I try disable Nouveau driverā¦fail
Please i need help š
