Hello
Jetson Orin Nano 8GB, 36.3
I have the jetson-containers with ollama, open-web-ui und stable-diffusion running.
When stable-diffusion generates two or three small images in a row I get power warnings or the JON even reboots.
The NVP Model Clock Configuration for Jetson Orin Nano 8GB only allows for 15W (mode 0), on which I am.
https://docs.nvidia.com/jetson/archives/r36.2/DeveloperGuide/SD/PlatformPowerAndPerformance/JetsonOrinNanoSeriesJetsonOrinNxSeriesAndJetsonAgxOrinSeries.html#supported-modes-and-power-efficiency
Is this normal behaviour and is there a way around? The power supply has 45W.
Thank you
Hi
Do you see the overcurrent warning?
If yes, it is expected when running complicated tasks like inference.
Thank you @AastaLLL a kind of unexpected answer.
That seems to do the trick. I set it to 7.5W and no problems since then.
system
Closed
9
