Dear all:
1: Jetson Orin Nano 8GB devkit in SUPER MAXN model, jetpack is jetpack6.2
2: As following picture show: CPU GPU and EMMC all load to full state, but the power just run to 13W.
3: GPU stress test: ./gpu-bure -d 1000 ; cpu stress test: stress -c 6 &
emmc test: memtester
4: According to the evaluator's evaluation, the loading level is 15W at low level, and can reach 23W at high levels.
So: How can we achieve high levels. or how to make jetson orin nano 8GB development board power up to 25W?
Thanks all !!! best regards!!!
Hi 848145724,
May I know what’s your use case? Just to test the highest power that Orin Nano could achieve?
Or you are running specific application in your case?
MAXN is just an un-constrained mode rather than best performance mode.
We would suggest creating a custom power mode configurations according to your running application or you might get throttling and get performance decreased.
You can simply check the dmesg or run the following commands to check if you got OC event.
# grep "" /sys/class/hwmon/hwmon*/oc*
From the image you shared, it seems you hit hot-surface issue.
Please also take care of the cooling plan in your setup.
Yes , we just want to test the highest power about jetson orin nano.
GPU stress test tool source code is here:https://codeload.github.com/anseeto/jetson-gpu-burn/
CPU stress test tool : sudo apt-get install stress
EMMC stress test tool: sudo apt-get install memtester
Following is related log when run stress test:
dmesg.log (59.6 KB)
It seems you don’t hit OC event and there’s no error in dmesg.
Do you share the results after you run the test?
I would expect there’re some messages showing “Caution-Hot surface. Do Not Touch.” which appears in original post.
Please also share the result of the following command on your board.
$ nvpmodel -q --verbose
$ cat /etc/nvpmodel.conf
Caution-Hot sorface, Do Not Touch appers in hdmi.
nvpmodel -q --verbose result :
ubuntu@ubuntu-desktop:~$ nvpmodel -q --verbose NVPM VERB: Config file: /etc/nvpmodel.conf NVPM VERB: parsing done for /etc/nvpmodel.conf NVPM VERB: Current mode: NV Power Mode: MAXN_SUPER 2 NVPM VERB: PARAM CPU_ONLINE: ARG CORE_0: PATH /sys/devices/system/cpu/cpu0/online: REAL_VAL: 1 CONF_VAL: 1 NVPM VERB: PARAM CPU_ONLINE: ARG CORE_1: PATH /sys/devices/system/cpu/cpu1/online: REAL_VAL: 1 CONF_VAL: 1 NVPM VERB: PARAM CPU_ONLINE: ARG CORE_2: PATH /sys/devices/system/cpu/cpu2/online: REAL_VAL: 1 CONF_VAL: 1 NVPM VERB: PARAM CPU_ONLINE: ARG CORE_3: PATH /sys/devices/system/cpu/cpu3/online: REAL_VAL: 1 CONF_VAL: 1 NVPM VERB: PARAM CPU_ONLINE: ARG CORE_4: PATH /sys/devices/system/cpu/cpu4/online: REAL_VAL: 1 CONF_VAL: 1 NVPM VERB: PARAM CPU_ONLINE: ARG CORE_5: PATH /sys/devices/system/cpu/cpu5/online: REAL_VAL: 1 CONF_VAL: 1 NVPM VERB: PARAM FBP_POWER_GATING: ARG FBP_PG_MASK: PATH /sys/devices/platform/gpu.0/fbp_pg_mask: REAL_VAL: 2 CONF_VAL: 2 NVPM VERB: PARAM TPC_POWER_GATING: ARG TPC_PG_MASK: PATH /sys/devices/platform/gpu.0/tpc_pg_mask: REAL_VAL: 240 CONF_VAL: 240 NVPM VERB: PARAM GPU_POWER_CONTROL_ENABLE: ARG GPU_PWR_CNTL_EN: PATH /sys/devices/platform/gpu.0/power/control: REAL_VAL: auto CONF_VAL: on NVPM VERB: PARAM CPU_A78_0: ARG MIN_FREQ: PATH /sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq: REAL_VAL: 1728000 CONF_VAL: 729600 NVPM VERB: PARAM CPU_A78_0: ARG MAX_FREQ: PATH /sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq: REAL_VAL: 1728000 CONF_VAL: 9223372036854775807 NVPM VERB: PARAM CPU_A78_1: ARG MIN_FREQ: PATH /sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq: REAL_VAL: 1728000 CONF_VAL: 729600 NVPM VERB: PARAM CPU_A78_1: ARG MAX_FREQ: PATH /sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq: REAL_VAL: 1728000 CONF_VAL: 9223372036854775807 NVPM VERB: PARAM CPU_A78_2: ARG MIN_FREQ: PATH /sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq: REAL_VAL: 1728000 CONF_VAL: 729600 NVPM VERB: PARAM CPU_A78_2: ARG MAX_FREQ: PATH /sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq: REAL_VAL: 1728000 CONF_VAL: 9223372036854775807 NVPM VERB: PARAM CPU_A78_3: ARG MIN_FREQ: PATH /sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq: REAL_VAL: 1728000 CONF_VAL: 729600 NVPM VERB: PARAM CPU_A78_3: ARG MAX_FREQ: PATH /sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq: REAL_VAL: 1728000 CONF_VAL: 9223372036854775807 NVPM VERB: PARAM CPU_A78_4: ARG MIN_FREQ: PATH /sys/devices/system/cpu/cpu4/cpufreq/scaling_min_freq: REAL_VAL: 1728000 CONF_VAL: 729600 NVPM VERB: PARAM CPU_A78_4: ARG MAX_FREQ: PATH /sys/devices/system/cpu/cpu4/cpufreq/scaling_max_freq: REAL_VAL: 1728000 CONF_VAL: 9223372036854775807 NVPM VERB: PARAM CPU_A78_5: ARG MIN_FREQ: PATH /sys/devices/system/cpu/cpu5/cpufreq/scaling_min_freq: REAL_VAL: 1728000 CONF_VAL: 729600 NVPM VERB: PARAM CPU_A78_5: ARG MAX_FREQ: PATH /sys/devices/system/cpu/cpu5/cpufreq/scaling_max_freq: REAL_VAL: 1728000 CONF_VAL: 9223372036854775807 NVPM VERB: PARAM GPU: ARG MIN_FREQ: PATH /sys/devices/platform/17000000.gpu/devfreq_dev/min_freq: REAL_VAL: 1020000000 CONF_VAL: 0 NVPM VERB: PARAM GPU: ARG MAX_FREQ: PATH /sys/devices/platform/17000000.gpu/devfreq_dev/max_freq: REAL_VAL: 1020000000 CONF_VAL: 9223372036854775807 NVPM VERB: PARAM GPU_POWER_CONTROL_DISABLE: ARG GPU_PWR_CNTL_DIS: PATH /sys/devices/platform/gpu.0/power/control: REAL_VAL: auto CONF_VAL: auto NVPM VERB: PARAM EMC: ARG MAX_FREQ: PATH /sys/kernel/nvpmodel_clk_cap/emc: REAL_VAL: 3199000000 CONF_VAL: 9223372036854775807
this is nvpmodel.conf file in /etc/
nvpmodel.conf.txt (8.0 KB)
Besides, after run following test, the power just up about 0.5W.
./video_dec_cuda ../../data/Video/sample_outdoor_car_1080p_10fps.h264 H264
Even if : run in 25W model, the power is about 10W.
It seems to diffcult up to 25w with jetson orin nano 8GB dev kit.
Does there are limit about power in system?
Thanks ~0618
I would expect some related messages also showing in dmesg/serial console log.
Could you also run sudo jetson_clocks and refer to the following instruction to run matrixMulCUBLAS and check the power consumption?
Jetson/L4T/TRT Customized Example - eLinux.org
