Power consumption nvidia Jetson Orin Nano Developer Kit 8GB
I create this forum because I would like to use the newest Nvidia Jetson Orin Nano Developer Kit (the 8GB version) inside a rocket for trajectory planning.
I look inside the data sheet, but I didn’t find anything clear about the maximum power consumption of the module in order to size my power bank for this.
Can you help me to find it?
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I have moved this post for better visibility.
Cheers,
Tom
Power consumption is use case dependent. Up to 7W, 15W, 25W power modes are supported this is assuming Vin of 5V@5A. If using Orin Nano Super power mode than up to 40W is supported with Vin minimum of 8V@5A. Please refer to View Jetson Orin Technical Specifications and in Jetson Orin Nano 8GB column.
for the overall power envelope.
Note that the Jetson Orin Nano Super Developer Kit supports 25W maximum. If need to support Jetson Orin Nano Super Module then you would need a custom carrier board.
