Jetson Orin Nano dev kit
I’m working with the Jetson Orin Nano dev kit and wanted to know the power consumption of the module in default mode, or any information about its maximum power consumption. I reviewed the documentation but couldn’t find this information. Do you have any documentation regarding this matter?
Thank you.
What’s the “default mode”? The power profile is defined by nvpmodel 7W/10W/15W. The real power consumption is case by case and depends on your use case. There is no maximum power data. In general, you can take the IDDmax=5A as the design limit which will lead to <25W. Below are the screenshot of module data sheet.
