I have a 32bit float RGB 2D array, interleaved, RGBRGBRGBRGB…
Compiles & runs with no errors.
Using nppiResize_32f_C3R, can someone please take a look at the below code, and try let me know what’s amiss. The section for single channel Grayscale/B&W works perfectly. The RGB code produces mumbo-jumbo. Thanks:
// NPPI_INTER_SUPER will reject a resizing call unless BOTH x/y axes are reduced in size.
// nppiMalloc & nppiFree links with -lnppisu library
// 2D pitched allocations
#include <Exceptions.h>
#include <cuda_runtime.h>
#include <npp.h>
#include <nppi.h>
#include <nppdefs.h>
#define CUDA_CALL(call) do { cudaError_t cuda_error = call; if(cuda_error != cudaSuccess) { std::cerr << "CUDA Error: " << cudaGetErrorString(cuda_error) << ", " << FILE << ", line " << LINE << std::endl; return(NULL);} } while(0)
float* decimate_cuda(float* readbuff, uint32_t nSrcH, uint32_t nSrcW, uint32_t nDstH, uint32_t nDstW, uint8_t byteperpixel)
if (byteperpixel == 1){ // source : byteperpixel == 1, Grayscale / B&W, 1 x 32 bit float, YYYY…
size_t srcStep;
size_t dstStep;
// rows = height; columns = width
NppiSize oSrcSize = {nSrcW, nSrcH};
NppiRect oSrcROI = {0, 0, nSrcW, nSrcH};
float *devSrc;
CUDA_CALL(cudaMallocPitch((void**)&devSrc, &srcStep, nSrcW * sizeof(float), nSrcH));
CUDA_CALL(cudaMemcpy2D((void**)devSrc, srcStep,(void**)readbuff, nSrcW * sizeof(Npp32f), nSrcW * sizeof(Npp32f), nSrcH, cudaMemcpyHostToDevice));
NppiSize oDstSize = {nDstW, nDstH};
NppiRect oDstROI = {0, 0, nDstW, nDstH};
float *devDst;
CUDA_CALL(cudaMallocPitch((void**)&devDst, &dstStep, nDstW * sizeof(float), nDstH));
NppStatus result = nppiResize_32f_C1R(devSrc, // Y floats
srcStep, // nSrcW * 3 for RGB, // stride / pitch
oSrcSize,
oSrcROI,
devDst,
dstStep, // nDstW * 3 for RGB, // stride / pitch
oDstSize,
oDstROI,
NPPI_INTER_SUPER);
if (result != NPP_SUCCESS) {
std::cerr << "Unable to run decimate_cuda, error " << result << std::endl;
Npp64s writesize;
Npp32f *hostDst;
writesize = (Npp64s) nDstW * nDstH; // Y
if(NULL == (hostDst = (Npp32f *)malloc(writesize * sizeof(Npp32f)))){
printf("Error : Unable to alloctae hostDst in decimate_cuda, exiting...\n");
exit(1);
CUDA_CALL(cudaMemcpy2D(hostDst, nDstW * sizeof(Npp32f),(void**)devDst, dstStep, nDstW * sizeof(Npp32f),nDstH, cudaMemcpyDeviceToHost));
// nppiFree(devSrc);
// nppiFree(devDst);
CUDA_CALL(cudaFree(devSrc));
CUDA_CALL(cudaFree(devDst));
return(hostDst);
} // source : byteperpixel == 1, Grayscale / B&W, 1 x 32 bit float, YYYY...
else if (byteperpixel == 3){ // source : byteperpixel = 3 x 32bit float interleaved RGBRGBRGB...
size_t srcStep;
size_t dstStep;
float *devSrc;
CUDA_CALL(cudaMallocPitch((void**)&devSrc, &srcStep, 3 * nSrcW * sizeof(float), nSrcH));
CUDA_CALL(cudaMemcpy2D((void**)devSrc, srcStep, (void**)readbuff, 3 * nSrcW * sizeof(Npp32f), nSrcW * sizeof(Npp32f), nSrcH, cudaMemcpyHostToDevice));
float *devDst;
CUDA_CALL(cudaMallocPitch((void**)&devDst, &dstStep, 3 * nDstW * sizeof(float), nDstH));
NppStatus result = nppiResize_32f_C3R(devSrc, // RGB floats
oSrcSize,
oSrcROI,
devDst,
oDstSize,
oDstROI,
NPPI_INTER_SUPER);
Npp64s writesize;
Npp32f *hostDst;
writesize = (Npp64s) nDstW * nDstH * 3; // RGB
exit(1);
CUDA_CALL(cudaMemcpy2D((void**)hostDst, nDstW * sizeof(Npp32f), (void**)devDst, dstStep, nDstW * sizeof(Npp32f),nDstH, cudaMemcpyDeviceToHost));
return(hostDst);
} // source : byteperpixel == 3; 3 x 32bit float interleaved RGBRGBRGB...
return(0);
