After starting graphics debugging of the application, the Debugger fails with “Unsupported operation encountered” message. The only entry in the compatibility log is glTexImage3D. This function is definitely in 4.5 core profile. So, according to the documentation, it should be supported, right?
The environment: Windows 7, 64 bit; MSVC 2015; K3100 card; all recent drivers installed.
Any explanation or suggestion would be greatly appreciated.
Thank you for your reply. Yes, it was a typo. After all, with glTextImage3d the code would not even compile.
About my code sample: I tested several different 3D-rendering projects, some use OpenGL from QT, some call OpenGL functions directly. And they all have the same issue with unsupported glTexImage3D. So, it seems to me that the problem has nothing to do with our code. After all, it is always the same call to OpenGL32.dll.
I am sure, NVIDIA developers should have a very sophisticated environment to test NSIGHT with all OpenGL functions, so why do you need my code?
I tested an OpenGL sample with an internal Nsight build, it worked fine with nsight, no unsupported message about glTexImage3D.
OS: WIN7 64bit
Visual Studio: VS2015
GPU: GTX 670(which is also GK104)
driver: 388.30
Sample: gl-320-texture-3d which used the function glTexImage3D, link is https://github.com/g-truc/ogl-samples.
Can you try the sample above please? If the issue still happened, please wait for the release build and then test your sample again.
So, the function works from the test in both Debug and Release modes. But I have no clue why, or how to change our code to make it work. Actually, it is not exactly our code, it is QT. However, all OpenGL functions in QT should be used exactly the same way, so why only this one has an issue is a mystery.
I will leave the comment here as soon as I will figure it out.
By the way, Nsight is amazing. The ability to debug shaders make the development so much more productive, I don’t believe it.
