NVIDIA® Nsight™ Graphics 2019.3 is now available.
NVIDIA Nsight Graphics 2019.3 is now available for download! Version 2019.3 includes the following enhancements and bug fixes:
Feature Enhancement: GPU Trace
Metrics Graphs:
---Revamped GPU Trace Activity and corresponding user interface
---Inspect detailed performance metrics including hardware unit throughputs, SM occupancy, instruction and memory throughput, cache hit rates, and much more
Regime Table - Drill into perf marker regions and easily inspect unit throughputs
Improved Overhead - Substantially lower overhead and accuracy than the previous version
Feature Enhancement: Range Profiler
Configurable Range Profiler:
---Now the default view in the profiling activity (original view is now the (Legacy) Range Profiler)
---Enable, disable, or create custom sections
---Write rules into the section files that create notifications in the UI when the rule's conditions are met
Feature Enhancement: Acceleration Structure Viewer
Acceleration Structure Export - Export standalone AS files that can be viewed later without having a C++
capture or the live application
Feature Enhancement: Events View
Better marker hierarchy – Improved visibility and detail in the events view
New Support: Windows 19H1 (Partial)
Applications using RS5 APIs on 19H1 targets are now supported
New Support: OpenGL Extensions
GL_OVR_multiview and GL_OVR_multiview_multisampled_render_to_texture
New Support: Vulkan Extensions
VK_EXT_conditional_rendering
Improved:
Runtime overhead on D3D11 applications has been dramatically reduced
General stability – 230 Bugs fixed this release!
10x speed up when building C++ Captures in release
Fixed stability when running NVIDIA Nsight Aftermath and Microsoft PIX concurrently - Aftermath will be disabled when PIX is detected
Release Spotlight Video:
Download Nsight Graphics 2019.3 here: https://developer.nvidia.com/gameworksdownload#?dn=nvidia-nsight-graphics-2019-3
