nsight immidtaley crashes upon startup, not sure how to troubleshoot further.
Hi blg,
Have you tried re-installing the OS? I know this is drastic, but it appears that important components may be missing in your current installation. This could manifest as other issues in the future as well.
I’m going to look into other products that don’t require a fresh OS install to function. I have several applications that are dependent on .NET 3.5 and the VSredists and run without issue. Thanks for your time, it is much appreciated. If I do end up finding a solution I will make sure to share it.
