Basically, I would have thought the using Nsight would allow devs to see why something is crashing, but, instead, Nsight crashes as well.
This is a openGL program, and Aftermath only works on DX, so, how do we proceed here?
The same code was tested on both intel & AMD gear, and it works fine, so, it sure looks like a Nvidia openGL driver bug here…
EXCEPTION_PARAMETER1: 00000008
EXCEPTION_PARAMETER2: 00020052
WRITE_ADDRESS: 00020052
FOLLOWUP_IP:
nvoglv32+83afb6
58d3afb6 ?? ???
FAILED_INSTRUCTION_ADDRESS:
+83afb6
00020052 ?? ???
FAULTING_THREAD: 00003ac8
BUGCHECK_STR: APPLICATION_FAULT_SOFTWARE_NX_FAULT_INVALID
PRIMARY_PROBLEM_CLASS: SOFTWARE_NX_FAULT_INVALID
DEFAULT_BUCKET_ID: SOFTWARE_NX_FAULT_INVALID
LAST_CONTROL_TRANSFER: from 58d3afb6 to 00020052
STACK_TEXT:
WARNING: Frame IP not in any known module. Following frames may be wrong.
07a6dc70 58d3afb6 00008246 00008250 00020052 0x20052
07a6dc74 00000000 00008250 00020052 00009147 nvoglv32+0x83afb6
STACK_COMMAND: ~5s; .ecxr ; kb
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nvoglv32+83afb6
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nvoglv32
IMAGE_NAME: nvoglv32.dll
DEBUG_FLR_IMAGE_TIMESTAMP: 5a4d6882
FAILURE_BUCKET_ID: SOFTWARE_NX_FAULT_INVALID_c0000005_nvoglv32.dll!Unknown
BUCKET_ID: APPLICATION_FAULT_SOFTWARE_NX_FAULT_INVALID_BAD_IP_nvoglv32+83afb6
AYan
March 12, 2018, 3:56am
2
Hi ShadowCam,
Sorry for the crash you meet, but from your words, you mean your app also crash even without Nsight, right? I am sorry that Nsight doesn’t support a app that will crash.
An
Hi, well, the app don’t crash per se, the driver is crashing (nvoglv32.dll).
I thought Nsight was used for debugging GPU code?
Is there another tool I can use to help debug the driver crashing?
AYan
March 12, 2018, 7:35am
4
Hi ShadowCam,
I am not very understand your meaning, do you mean the app runs smoothly, and nvoglv32.dll will crash? Which process does the crash happen?
An
Yes, the program doesn’t crash on intel & AMD, only on Nvidia’s driver, nvoglv32.dll.
This is why we are using Nsight to try and debug why it only crashes in nvoglv32.dll, however, when the driver crashes, so does Nsight.
I would have thought Nsight would tell us the calls right before the crash so we can narrow it down.
Access Violation at location 00020052 Writing to location 00000000.
Registers:
eax=00000000 ebx=1886fd38 ecx=00000000 edx=00000001 esi=00008246 edi=00000001
eip=00020052 esp=15c8df28 ebp=00008250 iopl=0 nv up ei pl nz na pe nc
cs=0023 ss=002b ds=002b es=002b fs=0053 gs=002b efl=00010202
Call stack:
00020052
5B35AFB6 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B35AFB6
5B35B0E6 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B35B0E6
5B35B095 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B35B095
5B567EBF C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B567EBF DrvPresentBuffers
5B634D71 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B634D71 DrvPresentBuffers
5ABDF7D9 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5ABDF7D9
5ABCA741 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5ABCA741
5B635456 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B635456 DrvPresentBuffers
5B63666E C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B63666E DrvPresentBuffers
5B63546A C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B63546A DrvPresentBuffers
5B55A71A C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B55A71A DrvPresentBuffers
5B564A30 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B564A30 DrvPresentBuffers
5B580669 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B580669 DrvPresentBuffers
5B63082E C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B63082E DrvPresentBuffers
5B637E24 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B637E24 DrvPresentBuffers
5ABC5B89 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5ABC5B89
5B5335DF C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B5335DF DrvValidateVersion
5B618EB7 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B618EB7 DrvPresentBuffers
5B607CE1 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B607CE1 DrvPresentBuffers
5B60762F C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B60762F DrvPresentBuffers
5B541A51 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B541A51 DllMain
5B541B9C C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B541B9C DllMain
5B5419D2 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B5419D2 DllMain
5B541590 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B541590 DllMain
5B52E3B5 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B52E3B5 DrvSwapLayerBuffers
5B54348A C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B54348A DllMain
5B3D19F4 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B3D19F4
5B3D1864 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5601d21ccd639df9\nvoglv32.dll:5B3D1864
5B5379E7
AYan
March 13, 2018, 4:17am
6
Hi ShadowCam,
Sorry, but I think Nsight doesn’t support a app that will crash. It’s better to ask for support from driver team, IMO.
An
