Nsight system showing wrong behaviour
I’m profilling my code using nsight systems with cuda 11.3 .
Here is the code i"m using for profilling ::
int main(int argc, char **argv)
    // Profilling Tags
    nvtxMarkA("XX");
    nvtxRangePushA("XX");
    // Initializing the Python
    Py_Initialize();
    // Importing the Os and appending Path in python
    PyRun_SimpleString("import sys\n"
                       "import os\n"
                       "sys.path.append(os.getcwd())\n");
    // Setting the precision and Type of Program
    Set_precision();
    // Setting the communications
    set_communications();
    // Setting the signal for interupt
    signal(SIGINT, signal_callback_handler);
    if (HYDRO_FLAG)
        if (!precision.compare("single"))
            Hydro<T1_f, T2_f>();
        if (!precision.compare("double"))
            Hydro<T1_d, T2_d>();
    if (SCALAR_FLAG || RBC_FLAG)
            Scalar<T1_f, T2_f>();
            Scalar<T1_d, T2_d>();
    if (MHD_FLAG)
            MHD<T1_f, T2_f>();
            MHD<T1_d, T2_d>();
    // Python Finalize
    Py_Finalize();
    nvtxRangePop();
    return 0;
But somehow when i’m opening the profilling file . Instead of 1 it is showing 3 XX runs . WHY ?? Can anyone help
Here , in the screenshot also you can see 3 calls . while it should be only one .
Hi manver,
NVTX ranges that wrap CUDA kernel launches are projected from the CPU onto the GPU, creating GPU-side annotations.
That is why the Events view displays multiple ranges with the same name instead of the single range you expected.
so whats the solution
