Nsight systems doesn't show workload trace
I’m running nsys in WSL2 on a windows 11 pc.
When I generate an nsys report in WSL and open it in the windows GUI, I can see CUDA API calls, CuDNN, CUBlas…, but the CUDA workload trace is missing.
I don’t think this is a problem with the application I’m running because I tried using code in Julia, as well as this pytorch example I found online.
Is this a bug or could I be doing something unsupported?
edit:
Here’s an example of a generated report:
my_profile.nsys-rep (176.5 KB)
@jcohen to respond
Any updates by any chance?
Thanks in advance!
The problem is that WSL user-mode processes run virtualized, so their CPU timestamps are shifted with respect to unvirtualized timestamps. Our method of getting clock synchronization between CPU and GPU work is implemented in the kernel-mode driver, which under WSL runs outside of the virtualization. So we implemented driver support to get conversion factors between the timestamps inside & outside of virtualization, and that is shipping in 520 series drivers. The only remaining work is for Nsight Systems to make use of the new driver support and add the extra layer of time conversions. I am planning to work on this next week.
Hi, i have some error when using nsys on WSL2,can i get your nsys cli command for reference?
(i just can’t get the report…nsys return error.)
If you’re also running Julia code, I followed these instructions.
For the Pytorch code I believe I simply copied the command from the example. Might be useful to open a new topic on the forums with the exact command and error you’re getting.
thanks for your replay, i think i should open a new topic as you said : )
