NV_GPU_DISPLAYIDS osVisible and physicallyConnected bits are always true
Title. Is this intended? If nothing is connected then how is a display visible to the OS and physically connected? The documentation for physically connected says that it’s only valid if the connected field is set, but having it set to true regardless is problematic.
Dear @BlueGoliath
Thank you for contacting NVIDIA developer forum.
Our technical team has received your query and we will get back to you after initial investigation.
Thanks,
NVAPI Forum Moderator
