We are facing an issue where our Healthcare application is unable to connect to NVidia GPU (rather it is disabled) if no monitor is connected to the NVidia card. This is seen in Windows Server 2012, 2016, 2019 OS regardeless of NVidia card type. Is there a workaround for this issue?
Regards
Karthik
Hello @k.karthik
Thank you for contacting NVIDIA developer forum.
Our technical team has received your query and we will get back to you after initial investigation.
I have few questions to start with:
- Do you own the
healthcare application
that you are referring to? - What is the exact manifestation of
unable to connect to NVIDIA GPU (rather it is disabled)
→ do you see it it disabled or with a yellow bang in the device manager?
→ Is there any NVAPI that returns an error / some error is shown by the application?
→ Can you runnvidia-smi.exe
from system32 (on an admin command prompt) and share the output?
→ Can you also rundxdiag
and share the log file?
Thanks,
NVAPI Forum Moderator
Hello moderator,
Thanks for your response. Sorry I don’t have answers to all the questions since it happened in our customer site. I am checking if I can get the details. Meanwhile, let me see if I can provide you with more helpful info.
- Healthcare application is developed and owned by us
The other queries I’ll get you the response shortly. From what I understand, the symptoms of the issue is same as mentioned in this forum Redirecting. NVidia GPU shows in device manager without any yellow bang. However, when our application tries to check for GPU using WGLInfo, we don’t see the Nvidia GPU as enabled.
Hope this helps.
Regards
Karthik
Sorry for the delay in response. You may close this topic. The problem is internal to our application and we are working to resolve it.
Regards
Karthik
Hello @k.karthik
Thank you for your update. Hope you are have a good day. :)
Warm regards,
