GPU not showing up in lspci, drivers not working, Ubuntu 22.04
I have tried installing the drivers in so many different ways, but nothing I do makes the card show up in lspci or lshw. I have the latest headers, drivers, secure boot is disabled etc. but no luck so far. The PC is running in headless mode (no display attached), but for my latest attempt I installed all drivers normally (sudo apt-get install nvidia-open and sudo apt-get install cuda-drivers after adding the keyring).
Please find the logs below, perhaps someone more knowledgeable than me can spot what is wrong. Thanks, and sorry for yet another “my GPU isn’t working in Linux” post.
nvidia-bug-report.log (1.7 MB)
Hardware:
CPU: Intel(R) Core™ i3 540
GPU: Nvidia GTX 1650
Motherboard: DQ57TM
RAM: 12GB DDR3
~$ lspci -nn | grep -Ei "nv|vga|3d|display"
00:02.0 VGA compatible controller [0300]: Intel Corporation Core Processor Integrated Graphics Controller [8086:0042] (rev 02)
~$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
~$ uname -a
Linux nas 6.8.0-51-generic #52~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Mon Dec  9 15:00:52 UTC 2 x86_64 x86_64 x86_64 GNU/Linux
~$ dpkg -l | grep -i nvidia
ii  libnvidia-cfg1-565:amd64                                    565.57.01-0ubuntu1                      amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-565                                        565.57.01-0ubuntu1                      all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-565:amd64                                 565.57.01-0ubuntu1                      amd64        NVIDIA libcompute package
ii  libnvidia-decode-565:amd64                                  565.57.01-0ubuntu1                      amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-565:amd64                                  565.57.01-0ubuntu1                      amd64        NVENC Video Encoding runtime library
ii  libnvidia-extra-565:amd64                                   565.57.01-0ubuntu1                      amd64        Extra libraries for the NVIDIA driver
ii  libnvidia-fbc1-565:amd64                                    565.57.01-0ubuntu1                      amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-565:amd64                                      565.57.01-0ubuntu1                      amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  nvidia-compute-utils-565                                    565.57.01-0ubuntu1                      amd64        NVIDIA compute utilities
ii  nvidia-dkms-565-open                                        565.57.01-0ubuntu1                      amd64        NVIDIA DKMS package (open kernel module)
ii  nvidia-driver-565-open                                      565.57.01-0ubuntu1                      amd64        NVIDIA driver (open kernel) metapackage
ii  nvidia-firmware-565-565.57.01                               565.57.01-0ubuntu1                      amd64        Firmware files used by the kernel module
ii  nvidia-kernel-common-565                                    565.57.01-0ubuntu1                      amd64        Shared files used with the kernel module
ii  nvidia-kernel-open-565                                      565.57.01-0ubuntu1                      amd64        Transitional package for nvidia-kernel-open-565
ii  nvidia-kernel-source-565-open                               565.57.01-0ubuntu1                      amd64        NVIDIA kernel source package
ii  nvidia-modprobe                                             565.57.01-0ubuntu1                      amd64        Load the NVIDIA kernel driver and create device files
ii  nvidia-prime                                                0.8.17.1                                all          Tools to enable NVIDIA's Prime
ii  nvidia-settings                                             565.57.01-0ubuntu1                      amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-utils-565                                            565.57.01-0ubuntu1                      amd64        NVIDIA driver support binaries
ii  screen-resolution-extra                                     0.18.2                                  all          Extension for the nvidia-settings control panel
ii  xserver-xorg-video-nvidia-565                               565.57.01-0ubuntu1                      amd64        NVIDIA binary Xorg driver
~$ dpkg -l | grep -i cuda
ii  cuda-drivers                                                565.57.01-0ubuntu1                      amd64        CUDA Driver meta-package, branch-agnostic
ii  cuda-drivers-565                                            565.57.01-0ubuntu1                      amd64        CUDA Driver meta-package, branch-specific
ii  cuda-keyring                                                1.1-1                                   all          GPG keyring for the CUDA repository
If the card isn’t showing in lspci, no driver will find it as the system has not recognised it.
Check to make sure it’s properly seated and if so, try another PCIe slot if you haven’t already.
Thanks for the info. It is possible that this is a hardware issue. I will post an update if/when I get a chance to try the card on a different motherboard in a few weeks.
