echo devices > /sys/power/pm_test
echo platform > /sys/power/disk
echo disk > /sys/power/state
- the system will hibernate and return back from hibernation. Console works fine, machine is not locked while in tty1
- try to return to X11 (alt-F7) - the screen will be blanked out, no response from video card.
machine is not locked, possible to log on via ssh.
Same result when trying to hibernate from XFce
Same problem/bug was with old driver 280.13
Xorg.0.log contains:
(II) Open ACPI successful (/var/run/acpid.socket)
(WW) Mar 31 21:56:54 NVIDIA(GPU-0): Failed to enter interactive mode.
(II) Mar 31 21:56:54 NVIDIA(0): Setting mode “nvidia-auto-select”
(EE) Mar 31 21:56:54 NVIDIA(0): Failed to initiate mode change
the console is completely blocked until remotely X server is killed, then it respawns fine.
nvidia-bug-report.log.gz (71.4 KB)
