I found in the process of using nvarguscamerasrc that setting wbmode=1, when I changed the color temperature of the environment, the picture was also changing, and the automatic white balance did not take effect.
gst-launch-1.0 nvarguscamerasrc sensor-id=1 wbmode=1 ee-mode=0 ! "video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, format=(string)NV12, framerate=(fraction)15/1" ! nvvidconv ! videoconvert ! xvimagesink
The following is a video recorded by manually adjusting the ambient color temperature after running the command. It can be seen from the screen that the color is changing and the automatic white balance is not effective.
43722c87e38ecbc06045d22abe12b2df.zip (7.5 MB)
