I have the multi camera system with 4 mipi-csi camera on Xavier R32.1.
Now I use the gst-launch-1.0 nvarguscamerasrc to open each camera.
For open the 2th camera:
nvidia@nvidia-desktop:~$ gst-launch-1.0 nvarguscamerasrc <b>sensor-id=1</b> ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1' ! nvoverlaysink -e
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
<b>Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:525 Invalid camera device specified 1 specified, 0 max index</b>
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
As above, I can not specified the camera but the 1th camera.
I can only use sensor-id=0 to open the /dev/video0 success, Other will be error.
How can i specified other camera use gst-launch-1.0 nvarguscamerasrc?
Thanks for your suggestions, they are helpfull.
It is dure to “drivernode0” in DTS.
Now, can use “sensor-id” to open the specified port camera success.
@JerryChang I have 2 rpi cameras connected through auvidea jn30a but when i type ls /dev/video* gives me only one output “/dev/video0” what should i do to enable the other one
Note : i tested the 2 cameras in the working port and they are working
this discussion thread has been closed.
could you please initial another new topic, please also include all the details information for further support.
thanks
