system info : tx1 kernel version 3.10.96.
I use six cameras handling on the i2c switch pca9548. I can get the six node in /dev ,which are /dev/video0~5.
Then I run the following command:
gst-launch-1.0 nvcamerasrc sensor-id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1, format=NV12' ! nvoverlaysink -ev
I can get the preview correctly. but when I change the sensor-id to 1,2,3,4 and 5. I get some error.
In the kernel source kernel_source/drivers/i2c/muxes/i2c-mux-pca954x.c, I add printk in the function :
pca954x_select_chan(struct i2c_adapter *adap, void *client ,u32 chan)
{printk(KERN_ERR "the chan value :%d",chan);}
Then I find everytime I use gst-launch-1.0 command ,whatever sensor-id I set to, the chan value is always 0.
I also try v4l2-ctl:
v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --stream-mmap --stream-count=1 --stream-to=imx219.raw
when I set the -d to /dev/video0~5, the chan value from printk changes :
/dev/video# chan value
/dev/video0 0
/dev/video1 1
/dev/video2 2
/dev/video3 3
/dev/video4 4
/dev/video5 5
Using v4l2-ctl I can get the bayer image from six camera correctly.Maybe it’s not the matter of my dtb and driver source.
So I wonder if it’s the problem of nvcamerasrc .Does NVIDIA engineer have clues to that?
I wanna know which function in the tx1 kernel source code the command “nvcamerasrc sensor-id=x” will call firstly and pass the value of sensor-id to the kernel code .I just need pass the value of sensor-id to the chan. Could NVIDIA engineer help me with it ?
Regards.
