The NVIDIA HPC SDK documentation says that:
Linux installations require some version of the GNU Compiler Collection (including gcc, g++, and gfortran compilers) to be installed and in your $PATH prior to installing HPC SDK software.
But what exactly does nvc++ need g++ for? Is it just for libstdc++?
If so, then is there any way to configure nvc++ to include a different standard library such as libc++ instead?
As discussed in Cpp2 TERMINATED by signal 11, libstdc++ is using a data type that is not compatible with stdpar, and I would like to check whether the same issue exists with libc++ as well.
