Nvcc error : 'cicc' died with status 0xC0000005 - Only in DEBUG mode
I’m trying to compile the latest dev version of my cuda_voxelizer project: GitHub - Forceflow/cuda_voxelizer at dev
In Release mode (x64), the compilation succeeds, and my compiled result behaves like I expect it to, getting correct results from my tests (voxelizing polygon structures).
In Debug mode (x64), the compilation fails because NVCC crashes.
Build started...
1>------ Build started: Project: cuda_voxelizer, Configuration: Debug x64 ------
1>Compiling CUDA source file ..\..\src/voxelize.cu...
1>Compiling CUDA source file ..\..\src\voxelize_solid.cu...
1>
1>D:\dev\cuda_voxelizer\msvc\vs2022>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" -gencode=arch=compute_60,code=\"sm_60,compute_60\" -gencode=arch=compute_61,code=\"sm_61,compute_61\" -gencode=arch=compute_70,code=\"sm_70,compute_70\" -gencode=arch=compute_75,code=\"sm_75,compute_75\" -gencode=arch=compute_80,code=\"sm_80,compute_80\" --use-local-env -ccbin "C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.36.32532\bin\HostX64\x64" -x cu   -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\include"  -G   --keep-dir x64\Debug  -maxrregcount=0   --machine 64 --compile -cudart static --source-in-ptx -g  -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -Xcompiler "/Fdx64\Debug\vc143.pdb" -o D:\dev\cuda_voxelizer\msvc\vs2022\x64\Debug\voxelize.cu.obj "D:\dev\cuda_voxelizer\src\voxelize.cu"
1>
1>D:\dev\cuda_voxelizer\msvc\vs2022>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" -gencode=arch=compute_60,code=\"sm_60,compute_60\" -gencode=arch=compute_61,code=\"sm_61,compute_61\" -gencode=arch=compute_70,code=\"sm_70,compute_70\" -gencode=arch=compute_75,code=\"sm_75,compute_75\" -gencode=arch=compute_80,code=\"sm_80,compute_80\" --use-local-env -ccbin "C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.36.32532\bin\HostX64\x64" -x cu   -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\include"  -G   --keep-dir x64\Debug  -maxrregcount=0   --machine 64 --compile -cudart static --source-in-ptx -g  -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -Xcompiler "/Fdx64\Debug\vc143.pdb" -o D:\dev\cuda_voxelizer\msvc\vs2022\x64\Debug\voxelize_solid.cu.obj "D:\dev\cuda_voxelizer\src\voxelize_solid.cu"
1>voxelize.cu
1>CUDACOMPILE : nvcc error : 'cicc' died with status 0xC0000005 (ACCESS_VIOLATION)
1>C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.1.targets(799,9): error MSB3722: The command ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" -gencode=arch=compute_60,code=\"sm_60,compute_60\" -gencode=arch=compute_61,code=\"sm_61,compute_61\" -gencode=arch=compute_70,code=\"sm_70,compute_70\" -gencode=arch=compute_75,code=\"sm_75,compute_75\" -gencode=arch=compute_80,code=\"sm_80,compute_80\" --use-local-env -ccbin "C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.36.32532\bin\HostX64\x64" -x cu   -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\include"  -G   --keep-dir x64\Debug  -maxrregcount=0   --machine 64 --compile -cudart static --source-in-ptx -g  -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -Xcompiler "/Fdx64\Debug\vc143.pdb" -o D:\dev\cuda_voxelizer\msvc\vs2022\x64\Debug\voxelize.cu.obj "D:\dev\cuda_voxelizer\src\voxelize.cu"" exited with code 5. Please verify that you have sufficient rights to run this command.
1>Done building project "cuda_voxelizer.vcxproj" -- FAILED.
1>voxelize_solid.cu
1>C:\Program Files\Microsoft Visual Studio\2022\Community\MSBuild\Microsoft\VC\v170\BuildCustomizations\CUDA 12.1.targets(799,9): error MSB3722: The command ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\bin\nvcc.exe" -gencode=arch=compute_52,code=\"sm_52,compute_52\" -gencode=arch=compute_60,code=\"sm_60,compute_60\" -gencode=arch=compute_61,code=\"sm_61,compute_61\" -gencode=arch=compute_70,code=\"sm_70,compute_70\" -gencode=arch=compute_75,code=\"sm_75,compute_75\" -gencode=arch=compute_80,code=\"sm_80,compute_80\" --use-local-env -ccbin "C:\Program Files\Microsoft Visual Studio\2022\Community\VC\Tools\MSVC\14.36.32532\bin\HostX64\x64" -x cu   -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v12.1\include"  -G   --keep-dir x64\Debug  -maxrregcount=0   --machine 64 --compile -cudart static --source-in-ptx -g  -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /FS /Zi /RTC1 /MDd " -Xcompiler "/Fdx64\Debug\vc143.pdb" -o D:\dev\cuda_voxelizer\msvc\vs2022\x64\Debug\voxelize_solid.cu.obj "D:\dev\cuda_voxelizer\src\voxelize_solid.cu"" exited with code 5. Please verify that you have sufficient rights to run this command.
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
========== Build started at 1:39 PM and took 03,031 seconds ==========
As far as I can tell, my code doesn’t do anything out of the ordinary. The only external library I’m using in the kernels is the helper_cuda_math files from the official CUDA Samples. This is an example of a .cu file that fails to compile in DEBUG.
Update: Removing the –source-in-ptx option from the debug options resolves the issue, but makes my debug builds useless, afaik.
It’s hard to narrow down what the offending line is, because I’m getting no feedback. When I comment out nearly everything in the .cu files, the project continues, but uncommenting doesn’t narrow it down, seems random.
This has been happening on every release of the 12.x CUDA branch.
I can compile the CUDA Samples in Release and Debug Mode just fine, so I doubt anything is wrong with my CUDA install. I’ve got a relatively new card (4070 Ti). Can’t remember this happening on my older card (RTX 2070 Super).
Already tried:
  • Starting over with a totally new Visual Studio CUDA project, and adding my sources again, but I bump into the same problem.
  • Clean install of graphics drivers
  • New CUDA install
My environment:
Windows 10
Cuda 12.1
RTX 4070 TI, latest drivers
VS2022, latest updates
Any ideas?
I can reproduce this problem, or at least a very similar one, on Linux (RHEL8, x86_64) with CUDA 12.1
$ nvcc --version
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Tue_Feb__7_19:32:13_PST_2023
Cuda compilation tools, release 12.1, V12.1.66
Build cuda_12.1.r12.1/compiler.32415258_0
cmake -DCMAKE_CUDA_FLAGS="--source-in-ptx -G" -DCMAKE_BUILD_TYPE=Debug .. -DTrimesh2_INCLUDE_DIR=../../trimesh2/include -DTrimesh2_LINK_DIR=../../trimesh2/lib.Linux64
followed by
make VERBOSE=1
results in:
[ 75%] Building CUDA object CMakeFiles/cuda_voxelizer.dir/src/voxelize.cu.o
/software/CUDA/12.1.0/bin/nvcc -forward-unknown-to-host-compiler  -I/tmp/trimesh2/include -isystem=/software/CUDA/12.1.0/include --source-in-ptx -G -g --generate-code=arch=compute_52,code=[compute_52,sm_52] -std=c++17 -MD -MT CMakeFiles/cuda_voxelizer.dir/src/voxelize.cu.o -MF CMakeFiles/cuda_voxelizer.dir/src/voxelize.cu.o.d -x cu -c /tmp/cuda_voxelizer/src/voxelize.cu -o CMakeFiles/cuda_voxelizer.dir/src/voxelize.cu.o
nvcc error   : 'cicc' died due to signal 11 (Invalid memory reference)
nvcc error   : 'cicc' core dumped
make[2]: *** [CMakeFiles/cuda_voxelizer.dir/build.make:146: CMakeFiles/cuda_voxelizer.dir/src/voxelize.cu.o] Error 139
This smells like a bug in the NVCC compiler to me, or perhaps it’s a problem with excessive memory usage (but not likely I think).
Similar problem with totally different code reported recently in Cicc crash when compiling pytorch
Looks like a good candidate for reporting a bug, see How to report a bug
@kenneth.hoste Thanks for the repro. The problem is, I think I’ve got to narrow it down to a minimal working example to demonstrate the bug.
Thanks for reporting this to NVBUG 4160838 . We confirmed this is a known issue to us and you are correct that it will be triggered with '–source-in-ptx -G ’ in debug mode . A fix is ready in house and it will target next CUDA release soon .
Update: Cuda 12.2 doesn’t fix it, but they’re targeting the fix for next release.
