nvcc exits with code 1, no error output.
I’m despairing in getting the CUDA SDK to run on Windows 10 with Visual Studio 2017 on my laptop (with a Geforce 1050 Max-Q).
For any .cu file I want to compile - no matter if its from examples or from other code that compiles perfectly fine on other machines, nvcc on my machine just returns 1 without giving any additional information, even when specifying the “–verbose” flag; no matter whether I run the command from Visual Studio or from the VS command line.
Example (excuse the german snippets, visual studio is installed in german as this is the system language):
1>------ Erstellen gestartet: Projekt: add_cuda, Konfiguration: Debug x64 ------
1>Compiling CUDA source file add.cu...
1>
1>C:\experiments\cuda\add_cuda>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\bin\nvcc.exe" -gencode=arch=compute_35,code=\"sm_35,compute_35\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio017\Community\VC\Tools\MSVC4.16.27023\bin\HostX86\x64" -x cu  -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include"  -G   --keep-dir x64\Debug -maxrregcount=0  --machine 64 --compile -cudart static  -g   -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fdx64\Debug\vc141.pdb /FS /Zi /RTC1 /MDd " -o x64\Debug\add.cu.obj "C:\experiments\cuda\add_cuda\add.cu"
1>C:\Program Files (x86)\Microsoft Visual Studio017\Community\Common7\IDE\VC\VCTargets\BuildCustomizations\CUDA 10.1.targets(762,9): error MSB3721: Der Befehl ""C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\bin\nvcc.exe" -gencode=arch=compute_35,code=\"sm_35,compute_35\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio017\Community\VC\Tools\MSVC4.16.27023\bin\HostX86\x64" -x cu  -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include"  -G   --keep-dir x64\Debug -maxrregcount=0  --machine 64 --compile -cudart static  -g   -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fdx64\Debug\vc141.pdb /FS /Zi /RTC1 /MDd " -o x64\Debug\add.cu.obj "C:\experiments\cuda\add_cuda\add.cu"" wurde mit Code 1 beendet.
1>Die Erstellung des Projekts "add_cuda.vcxproj" ist abgeschlossen -- FEHLER.
========== Erstellen: 0 erfolgreich, 1 fehlerhaft, 0 aktuell, 0 übersprungen ==========
Or
C:\>"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\bin\nvcc.exe" -gencode=arch=compute_35,code=\"sm_35,compute_35\" --use-local-env -ccbin "C:\Program Files (x86)\Microsoft Visual Studio017\Community\VC\Tools\MSVC4.16.27023\bin\HostX86\x64" -x cu  -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include" -I"C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v10.1\include"  -G   --keep-dir x64\Debug -maxrregcount=0  --machine 64 --compile -cudart static  -g   -DWIN32 -DWIN64 -D_DEBUG -D_CONSOLE -D_MBCS -Xcompiler "/EHsc /W3 /nologo /Od /Fdx64\Debug\vc141.pdb /FS /Zi /RTC1 /MDd " --verbose -o x64\Debug\add.cu.obj "C:\experiments\cuda\add_cuda\add.cu"
C:\>echo %errorlevel%
1
C:\>
when running above failing command in a x86_x64 command prompt (if I run it in a x64 command prompt I of course get a message ‘nvcc fatal : Compiler ‘cl.exe’ in PATH different than the one specified with -ccbin’). But as you can see, there is no output whatsoever.
So what could go wrong here? I have uninstalled and re-installed the CUDA SDK 2 times already, without any change.
How can I get more info on what is going on? Is nvcc writing a log file of some kind?
Nobody an idea what I can do? Is nvcc really that much of a black box that if it fails, it’s bad luck, no chance of finding out what’s wrong?
Fortunately in the meantime I got it to run under Ubuntu 19.04 on the same machine…
Anybody has a solution for it?
I ran in to the same issue, I think it’s because ccbin is set to a directory rather than an EXE. So I would try changing
-ccbin “C:\Program Files (x86)\Microsoft Visual Studio017\Community\VC\Tools\MSVC4.16.27023\bin\HostX86\x64”
to
-ccbin “C:\Program Files (x86)\Microsoft Visual Studio017\Community\VC\Tools\MSVC4.16.27023\bin\HostX86\x64\cl.exe”
(you would need to adapt this to your specific configuration; my path is a bit different)
Hope this may be useful!
where do you set ccbin? Is it supposed to be an environmental variable?
I’ve run into the same trouble and the code I’m trying to build is a VS2019 solution…
-ccbin is a parameter to nvcc, it sets the host compiler used by nvcc
I had the same issue and i have successfully solved it! in my case, the problem is that i use chinese as my system username, and seems like it caused nvcc crashes, maybe you can try to create a new system user with english username, it works for me
