NvDsInterfaceExt missing
OS Ubuntu 2204
Docker version 26.1.4, build 5650f9b
docker-compose version 1.29.2, build unknown
NVIDIA-SMI 555.42.02
CUDA Version: 12.5
Cuda compilation tools, release 12.5, V12.5.40
Build cuda_12.5.r12.5/compiler.34177558_0
rivermax_ubuntu2204_1.50.7
Deepstream 7.0.0
Graph Composer 4.0.0
I am using Graph Composer and I get missing NvDsInterfaceExt for all my graphs.
The sample graph AudioTest3sony.yaml is attached.
AudioTest3sony.yaml.txt (2.0 KB)
This is the error which I get:
2024-07-02 18:45:00,017 - Registry - ERROR - No matching variant found for extension: NvDsInterfaceExt version: 1.5.0
ERROR:No matching variant found for extension: NvDsInterfaceExt version: 1.5.0
2024-07-02 18:45:00,017 - Registry - ERROR - Requested target configuration arch: x86_64 os: linux distribution: ubuntu_22.04 cuda: 12.2 cudnn: 8.9.2 tensorrt: 8.6.1 deepstream: 6.4 vpi: 2.3.1
ERROR:Requested target configuration arch: x86_64 os: linux distribution: ubuntu_22.04 cuda: 12.2 cudnn: 8.9.2 tensorrt: 8.6.1 deepstream: 6.4 vpi: 2.3.1
2024-07-02 18:45:00,017 - Registry - ERROR - Extension variants found ['arch: aarch64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ', 'arch: x86_64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ']
ERROR:Extension variants found ['arch: aarch64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ', 'arch: x86_64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ']
2024-07-02 18:45:00,017 - Registry - ERROR - Failed to find extensions for manifest from graphs [‘/tmp/gxf_137014313660432/MyGraph4.yaml’]
ERROR:Failed to find extensions for manifest from graphs [‘/tmp/gxf_137014313660432/MyGraph4.yaml’]
2024-07-02 18:45:00.019 INFO gxf/gxe/gxe.cpp@183: Creating context
2024-07-02 18:45:00.019 ERROR gxf/gxe/gxe.cpp@255: LoadExtensionManifest Error: GXF_FAILURE
It thinks it is there:
bill@H4M5ibc:~$ registry extn list -n NvDsInterfaceExt
NvDsInterfaceExt : Interfaces and data components for DeepStream
Trying to sync shows this:
bill@H4M5ibc:~$ registry repo sync -n ngc-public
2024-07-02 19:10:31,174 - Registry - INFO - Syncing repo ngc-public …
2024-07-02 19:10:31,682 - Registry - INFO - 46 extensions found
2024-07-02 19:10:34,740 - Registry - INFO - Syncing extension NvDsBaseExt version 1.4.1
2024-07-02 19:10:34,744 - Registry - INFO - Syncing extension NvDsBaseExt version 1.2.0
2024-07-02 19:10:34,747 - Registry - INFO - Syncing extension NvDsBaseExt version 1.4.0
2024-07-02 19:10:36,197 - Registry - INFO - Syncing extension NvDsInferenceUtilsExt version 1.0.0
2024-07-02 19:10:36,214 - Registry - INFO - Syncing extension NvDsInterfaceExt version 1.5.0
2024-07-02 19:10:36,227 - Registry - INFO - Syncing extension NvDsInterfaceExt version 1.4.0
2024-07-02 19:10:36,240 - Registry - INFO - Syncing extension NvDsInterfaceExt version 1.1.0
2024-07-02 19:10:36,242 - Registry - INFO - Syncing extension NvDsInterfaceExt version 1.3.0
2024-07-02 19:10:36,447 - Registry - INFO - Syncing extension NvDsInterfaceExt version 1.0.0
2024-07-02 19:10:36,573 - Registry - INFO - Syncing extension NvDsMuxDemuxExt version 1.5.0
2024-07-02 19:10:51,863 - Registry - INFO - Syncing extension VideoEncoderIOExtension version 1.1.0
2024-07-02 19:10:53,499 - Registry - INFO - Updating database …
2024-07-02 19:11:52,730 - Registry - WARNING - Some extensions failed to sync. Check logs at /tmp/nvgraph_registry.log
nvgraph_registry.log (988.4 KB)
Repository synced
bill@H4M5ibc:~$
nvgraph_registry.log shows:
2024-07-02 19:11:02,753 - Registry - DEBUG - Skipping extension NvDsInferenceUtilsExt version 1.4.0
2024-07-02 19:11:02,769 - Registry - DEBUG - Removing stale extension NvDsInterfaceExt from repo ngc-public
2024-07-02 19:11:02,769 - Registry - DEBUG - Removing extension from cache ExtensionRecord(name=‘NvDsInterfaceExt’, version=‘1.5.0’, uuid=‘f787f50d-9004-4e85-88b9-1ed1894257f2’)
2024-07-02 19:11:03,945 - Registry - DEBUG - Incompatible gxf core version
2024-07-02 19:11:03,945 - Registry - DEBUG - Registry gxf core version: 4.0.0 Extension gxf core version: 2.4.2
2024-07-02 19:11:03,945 - Registry - DEBUG - Skipping extension NvDsBaseExt version 1.0.0
2024-07-02 19:11:03,953 - Registry - DEBUG - Incompatible gxf core version
I tried
bill@H4M5ibc:~$ registry extn import interface -n NvDsInterfaceExt -s 1.5.0 -d ext
2024-07-02 19:25:18,405 - Registry - INFO - Importing extension interface …
Extension interface imported successfully
but I don’t know what to use for directory?
How do I fix this?
it looks like I need to fix gxf core version
Have you tried the deepstream-test1 sample graph? can it work in your environment?
Yes. That works but doesn.t use that item.
How does the compiled test sample relate to Graph Composer?
registry repo sync -n ngc-public fails because:
and
and
How do I get ‘NvDsInterfaceExt’ built with the correct gxf core version to be accepted by registry repo sync -n ngc-public
No. It doesn’t work in Composer. Same problem.
DEBUG:Dependent extensions required [‘NvDsInterfaceExt:1.5.0’, ‘StandardExtension:2.5.0’, ‘MultimediaExtension:2.5.0’, ‘NvDsBaseExt:1.5.0’, ‘HttpExtension:0.4.0’, ‘NvDsSourceExt:1.5.0’, ‘NvDsMuxDemuxExt:1.5.0’, ‘NvDsInferenceExt:1.5.0’, ‘NvDsSampleModelsExt:1.5.0’, ‘NvDsOutputSinkExt:1.5.0’, ‘NvDsVisualizationExt:1.5.0’, ‘NvDsInferenceUtilsExt:1.5.0’]
DEBUG:Found a close match TargetConfig(platform=PlatformConfig(arch=‘x86_64’, os=‘linux’, distribution=‘ubuntu_22.04’), compute=ComputeConfig(cuda=None, cudnn=None, tensorrt=None, deepstream=‘7.0’, triton=None, vpi=None))
2024-07-07 15:43:38,872 - Registry - ERROR - No matching variant found for extension: NvDsInterfaceExt version: 1.5.0
2024-07-07 15:43:38,872 - Registry - ERROR - Requested target configuration arch: x86_64 os: linux distribution: ubuntu_22.04 cuda: 12.2 cudnn: 8.9.2 tensorrt: 8.6.1 deepstream: 6.4 vpi: 2.3.1
2024-07-07 15:43:38,872 - Registry - ERROR - Extension variants found ['arch: aarch64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ', 'arch: x86_64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ']
ERROR:Extension variants found [‘arch: aarch64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ‘, ‘arch: x86_64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ‘]
2024-07-07 15:43:38,872 - Registry - ERROR - Failed to find extensions for manifest from graphs [’/tmp/gxf_140168395714096/deepstream-test1.yaml’]
ERROR:Failed to find extensions for manifest from graphs [’/tmp/gxf_140168395714096/deepstream-test1.yaml’]
2024-07-07 15:43:38.876 INFO gxf/gxe/gxe.cpp@183: Creating context
2024-07-07 15:43:38.877 ERROR gxf/gxe/gxe.cpp@255: LoadExtensionManifest Error: GXF_FAILURE
Yes: I did Registry ngc-public Sync Repo
2024-07-07 15:55:53,683 - Registry - INFO - Syncing extension NvDsInterfaceExt version 1.1.0
INFO:Syncing extension NvDsInterfaceExt version 1.5.0
DEBUG:Downloading file /home/bill/.cache/nvgraph_registry/NvDsDewarperExt/1.3.0/1.3.0-linux-aarch64-ubuntu_20.04-ds-6.3/target.yaml
INFO:Syncing extension NvDsInterfaceExt version 1.1.0
2024-07-07 15:55:53,694 - Registry - INFO - Syncing extension NvDsInterfaceExt version 1.0.0
2024-07-07 15:55:53,695 - Registry - INFO - Syncing extension NvDsInterfaceExt version 1.3.0
INFO:Syncing extension NvDsInterfaceExt version 1.0.0
INFO:Syncing extension NvDsInterfaceExt version 1.3.0
DEBUG:Incompatible gxf core version
DEBUG:Registry gxf core version: 4.0.0 Extension gxf core version: 3.1.0
2024-07-07 15:57:08,851 - Registry - WARNING - Some extensions failed to sync. Check logs at /tmp/nvgraph_registry.log
WARNING:Some extensions failed to sync. Check logs at /tmp/nvgraph_registry.log
I can’t reproduce the failure you post here. Have you install the DeepStream 7.0 correctly before you install Graph Composer?
I tried a new install on a new system:
bill@H4Mdq:~/Downloads$ sudo apt install ./deepstream-7.0_7.0.0-1_amd64.deb
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
Note, selecting ‘deepstream-7.0’ instead of ‘./deepstream-7.0_7.0.0-1_amd64.deb’
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
deepstream-7.0 : Depends: libnvinfer8 (>= 8.0.0) but it is not installable
Depends: libnvinfer-dev (>= 8.0.0) but it is not installable
Depends: libnvparsers8 (>= 8.0.0) but it is not installable
Depends: libnvparsers-dev (>= 8.0.0) but it is not installable
Depends: libnvonnxparsers8 (>= 8.0.0) but it is not installable
Depends: libnvonnxparsers-dev (>= 8.0.0) but it is not installable
Depends: libnvinfer-plugin8 (>= 8.0.0) but it is not installable
Depends: libnvinfer-plugin-dev (>= 8.0.0) but it is not installable
E: Unable to correct problems, you have held broken packages.
Previously this worked but which repository needs to be loaded?
bill@H4Mdq:~/Downloads/glib/build$ version=“8.6.1.6-1+cuda12.0”
bill@H4Mdq:~/Downloads/glib/build$ sudo apt-get install graphsurgeon-tf=${version} libnvinfer-bin=${version} libnvinfer-dev=${version} libnvinfer-dispatch-dev=${version} libnvinfer-dispatch8=${version} libnvinfer-headers-dev=${version} libnvinfer-headers-plugin-dev=${version} libnvinfer-lean-dev=${version} libnvinfer-lean8=${version} libnvinfer-plugin-dev=${version} libnvinfer-plugin8=${version} libnvinfer-samples=${version} libnvinfer-vc-plugin-dev=${version} libnvinfer-vc-plugin8=${version} libnvinfer8=${version} libnvonnxparsers-dev=${version} libnvonnxparsers8=${version} libnvparsers-dev=${version} libnvparsers8=${version} onnx-graphsurgeon=${version} python3-libnvinfer-dev=${version} python3-libnvinfer-dispatch=${version} python3-libnvinfer-lean=${version} python3-libnvinfer=${version} tensorrt-dev=${version} tensorrt-libs=${version} tensorrt=${version} uff-converter-tf=${version}
E: Unable to locate package graphsurgeon-tf
E: Unable to locate package libnvinfer-bin
E: Unable to locate package libnvinfer-dev
E: Unable to locate package libnvinfer-dispatch-dev
E: Unable to locate package libnvinfer-dispatch8
E: Unable to locate package libnvinfer-headers-dev
E: Unable to locate package libnvinfer-headers-plugin-dev
E: Unable to locate package libnvinfer-lean-dev
E: Unable to locate package libnvinfer-lean8
E: Unable to locate package libnvinfer-plugin-dev
E: Unable to locate package libnvinfer-plugin8
E: Unable to locate package libnvinfer-samples
E: Unable to locate package libnvinfer-vc-plugin-dev
E: Unable to locate package libnvinfer-vc-plugin8
E: Unable to locate package libnvinfer8
E: Unable to locate package libnvonnxparsers-dev
E: Unable to locate package libnvonnxparsers8
E: Unable to locate package libnvparsers-dev
E: Unable to locate package libnvparsers8
E: Unable to locate package onnx-graphsurgeon
E: Unable to locate package python3-libnvinfer-dev
E: Unable to locate package python3-libnvinfer-dispatch
E: Unable to locate package python3-libnvinfer-lean
E: Unable to locate package tensorrt-dev
E: Unable to locate package tensorrt-libs
E: Unable to locate package uff-converter-tf
If you install the DeepStream and Graph Composer by yourself, please follow the Installation — DeepStream documentation 6.4 documentation exactly.
Thanks for the reply. I did that. Same issue.
DEBUG:Dependent extensions required [‘NvDsInterfaceExt:1.5.0’, ‘StandardExtension:2.5.0’, ‘MultimediaExtension:2.5.0’, ‘NvDsBaseExt:1.5.0’, ‘NvDsOutputSinkExt:1.5.0’, ‘NvDsCloudMsgExt:1.5.0’, ‘HttpExtension:0.4.0’, ‘NvDsSourceExt:1.5.0’, ‘DeepStreamExtensionTest:1.5.0’, ‘NvDsTranscodeExt:1.5.0’, ‘NvDsConverterExt:1.5.0’]
2024-07-11 08:23:08,045 - Registry - ERROR - No matching variant found for extension: NvDsInterfaceExt version: 1.5.0
2024-07-11 08:23:08,045 - Registry - ERROR - Requested target configuration arch: x86_64 os: linux distribution: ubuntu_22.04 cuda: 12.2 cudnn: 8.9.2 tensorrt: 8.6.1 deepstream: 6.4 vpi: 2.3.1
2024-07-11 08:23:08,045 - Registry - ERROR - Extension variants found ['arch: aarch64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ', 'arch: x86_64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ']
2024-07-11 08:23:08,045 - Registry - ERROR - Failed to find extensions for manifest from graphs [’/tmp/gxf_140346869235632/Player1.yaml’]
ERROR:Failed to find extensions for manifest from graphs [’/tmp/gxf_140346869235632/Player1.yaml’]
2024-07-11 08:23:08.057 INFO gxf/gxe/gxe.cpp@183: Creating context
2024-07-11 08:23:08.058 ERROR gxf/gxe/gxe.cpp@255: LoadExtensionManifest Error: GXF_FAILURE
Where does NvDsInterfaceExt version: 1.5.0 live? Which folder?
Normally your downloaded extension repo will be in “~/.cache/nvgraph_registry/”
I can’t reproduce your failure. Have you download the extension repo correctly?
How do download the extension repo?
Yes. I Sync-Repo/ngc-public.
How can I fix " Incompatible gxf core version"??
Please refer to Application Development Workflow — DeepStream documentation 6.4 documentation for downloading extensions.
bill@B4Mibc6:~/Documents$ nvidia-smi
Tue Jul 16 07:40:06 2024
| NVIDIA-SMI 535.183.06 Driver Version: 535.183.06 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
Processing: nvidia-bug-report.log.gz…===|
| 0 NVIDIA RTX 6000 Ada Gene… On | 00000000:01:00.0 Off | Off |
| 30% 26C P8 27W / 300W | 0MiB / 49140MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
This is what I get when I follow your instructions:
composer.log (20.5 KB)
nvidia-bug-report.log.gx wouldn’t upload
I’ll reply later with my fixed installation.
When I run composer on the foxed system I get this as reported above:
DEBUG:Removing extension from cache ExtensionRecord(name=‘NvDsInferenceUtilsExt’, version=‘1.5.0’, uuid=‘27856a43-5ad4-4d8e-be36-0ec2cf9bbb58’)
DEBUG:Registry gxf core version: 4.0.0 Extension gxf core version: 2.4.2
DEBUG:Skipping extension NvDsConverterExt version 1.0.0
DEBUG:Registry gxf core version: 4.0.0 Extension gxf core version: 2.5.0
DEBUG:Skipping extension NvDsInferenceUtilsExt version 1.1.1
DEBUG:Skipping extension NvDsCloudMsgExt version 1.0.0
DEBUG:Skipping extension NvDsBaseExt version 1.0.0
DEBUG:Skipping extension NvDsInferenceUtilsExt version 1.4.0
DEBUG:Registry gxf core version: 4.0.0 Extension gxf core version: 3.0.0
DEBUG:Skipping extension NvDsInferenceUtilsExt version 1.3.0
DEBUG:Skipping extension NvDsInterfaceExt version 1.1.0
DEBUG:Skipping extension NvDsInterfaceExt version 1.3.0
DEBUG:Removing stale extension NvDsInterfaceExt from repo ngc-public
As you can see many extensions were removed in the ngc-public repo sync.
How do I fix this:
DEBUG:Removing extension from cache ExtensionRecord(name=‘NvDsInterfaceExt’, version=‘1.5.0’, uuid=‘f787f50d-9004-4e85-88b9-1ed1894257f2’)
I followed your instructions and did the example shown. I get the same error running the sample:
2024-07-16 09:22:56,396 - Registry - ERROR - No matching variant found for extension: NvDsInterfaceExt version: 1.5.0
2024-07-16 09:22:56,396 - Registry - ERROR - Requested target configuration arch: x86_64 os: linux distribution: ubuntu_22.04 cuda: 12.2 cudnn: 8.9.2 tensorrt: 8.6.1 deepstream: 6.4 vpi: 2.3.1
2024-07-16 09:22:56,396 - Registry - ERROR - Extension variants found ['arch: aarch64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ', 'arch: x86_64 os: linux distribution: ubuntu_22.04 deepstream: 7.0 ']
2024-07-16 09:22:56,396 - Registry - ERROR - Failed to find extensions for manifest from graphs [’/tmp/gxf_134915085627728/deepstream-test1.yaml’]
ERROR:Failed to find extensions for manifest from graphs [’/tmp/gxf_134915085627728/deepstream-test1.yaml’]
2024-07-16 09:22:56.398 INFO gxf/gxe/gxe.cpp@183: Creating context
2024-07-16 09:22:56.398 ERROR gxf/gxe/gxe.cpp@255: LoadExtensionManifest Error: GXF_FAILURE
Here is a system which works. Notice the version numbers:
INFO:Registry:
Requested target configuration:
Selected extension variants:
NvDsInterfaceExt
Version: 1.4.0 Variant: arch: x86_64 os: linux distribution: ubuntu_22.04 deepstream: 6.4
StandardExtension
Version: 2.4.0 Variant: arch: x86_64 os: linux distribution: ubuntu_22.04 cuda: 12.2
MultimediaExtension
NvDsBaseExt
Version: 1.4.1 Variant: arch: x86_64 os: linux distribution: ubuntu_22.04 deepstream: 6.4
HttpExtension
Version: 0.3.0 Variant: arch: x86_64 os: linux distribution: ubuntu_22.04
NvDsSourceExt
NvDsMuxDemuxExt
NvDsInferenceExt
NvDsSampleModelsExt
NvDsOutputSinkExt
DEBUG:Registry:Importing ext libs from ngc repo for NvDsInterfaceExt
DEBUG:Registry:Using cached variant /home/bill/.cache/nvgraph_registry/ngc-public/f787f50d-9004-4e85-88b9-1ed1894257f2/1.4.0/linux/x86_64/ubuntu_22.04-ds-6.4/f787f50d-9004-4e85-88b9-1ed1894257f2.tar.gz
DEBUG:Registry:Importing ext libs from ngc repo for StandardExtension
DEBUG:Registry:Using cached variant /home/bill/.cache/nvgraph_registry/ngc-public/8ec2d5d6-b5df-48bf-8dee-0252606fdd7e/2.4.0/linux/x86_64/ubuntu_22.04-cuda-12.2/8ec2d5d6-b5df-48bf-8dee-0252606fdd7e.tar.gz
DEBUG:Registry:Importing ext libs from ngc repo for MultimediaExtension
DEBUG:Registry:Using cached variant /home/bill/.cache/nvgraph_registry/ngc-public/6f2d1afc-1057-481a-9da6-a5f61fed178e/2.4.0/linux/x86_64/ubuntu_22.04/6f2d1afc-1057-481a-9da6-a5f61fed178e.tar.gz
