DGPU
• DeepStream Version
5.0.0
• TensorRT Version
it uninstalled itself
440.95.01
After a recent apt-upgrade on x86-64, a bunch of cuda 10 stuff uninstalled itself in favor of cuda 11 things. At around the same time, DeepStream stopped working. I’ve tried re-installing from .deb but it appears the dependencies are not set correctly since otherwise it would install the required libraries along with it. My Nvidia apt source are as follows:
deb http://developer.download.nvidia.com/compute/cuda/repos/ubuntu1804/x86_64 /
deb http://developer.download.nvidia.com/compute/machine-learning/repos/ubuntu1804/x86_64 /
Nvinfer is installed, but gstreamer will no longer load the plugin. There were some errors about missing libraries which went away after a ldconfig (apparently the postinst script does not do this?), but it still wont’ load:
[mdegans@konjin] -- [/usr/lib/pkgconfig]
$ GST_DEBUG=4 gst-inspect-1.0 nvinfer
0:00:00.000155977 16224 0x562a31ab3a00 INFO GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.14.5
0:00:00.000237226 16224 0x562a31ab3a00 INFO GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/x86_64-linux-gnu
0:00:00.000292297 16224 0x562a31ab3a00 INFO GST_INIT gst.c:607:init_pre: Linux konjin 4.15.0-111-generic #112-Ubuntu SMP Thu Jul 9 20:32:34 UTC 2020 x86_64
0:00:00.000799747 16224 0x562a31ab3a00 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.001274844 16224 0x562a31ab3a00 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.001396651 16224 0x562a31ab3a00 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.001442692 16224 0x562a31ab3a00 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.001450120 16224 0x562a31ab3a00 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.001463824 16224 0x562a31ab3a00 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /home/mdegans/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.008433491 16224 0x562a31ab3a00 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/mdegans/.cache/gstreamer-1.0/registry.x86_64.bin in 0.006955 seconds
0:00:00.008458050 16224 0x562a31ab3a00 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /home/mdegans/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.009136235 16224 0x562a31ab3a00 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.009143597 16224 0x562a31ab3a00 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.009150778 16224 0x562a31ab3a00 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.009156113 16224 0x562a31ab3a00 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.009159794 16224 0x562a31ab3a00 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
No such element or plugin 'nvinfer'
$ GST_DEBUG=4 gst-inspect-1.0 nvstreammux
0:00:00.000160102 16226 0x556859afca00 INFO GST_INIT gst.c:586:init_pre: Initializing GStreamer Core Library version 1.14.5
0:00:00.000232560 16226 0x556859afca00 INFO GST_INIT gst.c:587:init_pre: Using library installed in /usr/lib/x86_64-linux-gnu
0:00:00.000269538 16226 0x556859afca00 INFO GST_INIT gst.c:607:init_pre: Linux konjin 4.15.0-111-generic #112-Ubuntu SMP Thu Jul 9 20:32:34 UTC 2020 x86_64
0:00:00.000772692 16226 0x556859afca00 INFO GST_INIT gstmessage.c:127:_priv_gst_message_initialize: init messages
0:00:00.001480638 16226 0x556859afca00 INFO GST_INIT gstcontext.c:84:_priv_gst_context_initialize: init contexts
0:00:00.001603388 16226 0x556859afca00 INFO GST_PLUGIN_LOADING gstplugin.c:317:_priv_gst_plugin_initialize: registering 0 static plugins
0:00:00.001643304 16226 0x556859afca00 INFO GST_PLUGIN_LOADING gstplugin.c:225:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.001649351 16226 0x556859afca00 INFO GST_PLUGIN_LOADING gstplugin.c:227:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.001659764 16226 0x556859afca00 INFO GST_REGISTRY gstregistry.c:1727:ensure_current_registry: reading registry cache: /home/mdegans/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.008549931 16226 0x556859afca00 INFO GST_REGISTRY gstregistrybinary.c:621:priv_gst_registry_binary_read_cache: loaded /home/mdegans/.cache/gstreamer-1.0/registry.x86_64.bin in 0.006876 seconds
0:00:00.008573039 16226 0x556859afca00 INFO GST_REGISTRY gstregistry.c:1583:scan_and_update_registry: Validating plugins from registry cache: /home/mdegans/.cache/gstreamer-1.0/registry.x86_64.bin
0:00:00.009247802 16226 0x556859afca00 INFO GST_REGISTRY gstregistry.c:1685:scan_and_update_registry: Registry cache has not changed
0:00:00.009254370 16226 0x556859afca00 INFO GST_REGISTRY gstregistry.c:1762:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.009258606 16226 0x556859afca00 INFO GST_INIT gst.c:807:init_post: GLib runtime version: 2.56.4
0:00:00.009262435 16226 0x556859afca00 INFO GST_INIT gst.c:809:init_post: GLib headers version: 2.56.4
0:00:00.009265105 16226 0x556859afca00 INFO GST_INIT gst.c:810:init_post: initialized GStreamer successfully
0:00:00.029278693 16226 0x556859afca00 INFO GST_PLUGIN_LOADING gstplugin.c:901:_priv_gst_plugin_load_file_for_registry: plugin "/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so" loaded
0:00:00.029292132 16226 0x556859afca00 INFO GST_ELEMENT_FACTORY gstelementfactory.c:361:gst_element_factory_create: creating element "nvstreammux"
0:00:00.029397351 16226 0x556859afca00 INFO GST_ELEMENT_PADS gstelement.c:670:gst_element_add_pad:<GstNvStreamMux@0x556859dda140> adding pad 'src'
Factory Details:
Rank primary (256)
Long-name Stream multiplexer
Klass Generic
Description N-to-1 pipe stream multiplexing
Author NVIDIA Corporation. Post on Deepstream for Tesla forum for any queries @ https://devtalk.nvidia.com/default/board/209/
Plugin Details:
Name nvdsgst_multistream
Description NVIDIA Multistream mux/demux plugin
Filename /usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_multistream.so
Version 5.0.0
License Proprietary
Source module nvmultistream
Binary package NVIDIA Multistream Plugins
Origin URL http://nvidia.com/
GObject
+----GInitiallyUnowned
+----GstObject
+----GstElement
+----GstNvStreamMux
Pad Templates:
SINK template: 'sink_%u'
Availability: On request
Capabilities:
video/x-raw(memory:NVMM)
format: { (string)NV12, (string)RGBA }
width: [ 1, 2147483647 ]
height: [ 1, 2147483647 ]
framerate: [ 0/1, 2147483647/1 ]
video/x-raw
SRC template: 'src'
Availability: Always
Capabilities:
Element has no clocking capabilities.
Element has no URI handling capabilities.
Pads:
SRC: 'src'
Pad Template: 'src'
Element Properties:
name : The name of the object
flags: readable, writable
String. Default: "nvstreammux0"
parent : The parent of the object
Object of type "GstObject"
batch-size : Maximum number of buffers in a batch
Unsigned Integer. Range: 0 - 1024 Default: 0
batched-push-timeout: Timeout in microseconds to wait after the first buffer is available
to push the batch even if the complete batch is not formed.
Set to -1 to wait infinitely
Integer. Range: -1 - 2147483647 Default: -1
width : Width of each frame in output batched buffer. This property MUST be set.
Unsigned Integer. Range: 0 - 4294967295 Default: 0
height : Height of each frame in output batched buffer. This property MUST be set.
enable-padding : Maintain input aspect ratio when scaling by padding with black bands.
Boolean. Default: false
gpu-id : Set GPU Device ID
live-source : Boolean property to inform muxer that sources are live.
num-surfaces-per-frame: Max number of surfaces per frame
Unsigned Integer. Range: 1 - 4 Default: 1
nvbuf-memory-type : Type of NvBufSurface Memory to be allocated for output buffers
flags: readable, writable, changeable only in NULL or READY state
Enum "GstNvBufMemoryType" Default: 3, "nvbuf-mem-cuda-unified"
(0): nvbuf-mem-default - Default memory allocated, specific to particular platform
(1): nvbuf-mem-cuda-pinned - Allocate Pinned/Host cuda memory
(2): nvbuf-mem-cuda-device - Allocate Device cuda memory
(3): nvbuf-mem-cuda-unified - Allocate Unified cuda memory
buffer-pool-size : Maximum number of buffers in muxer's internal pool
Unsigned Integer. Range: 0 - 1024 Default: 4
attach-sys-ts : If set to TRUE, system timestamp will be attached as ntp timestamp.
If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached.
Boolean. Default: true
0:00:00.030233413 16226 0x556859afca00 INFO GST_REFCOUNTING gstelement.c:3251:gst_element_dispose:<nvstreammux0> 0x556859dda140 dispose
0:00:00.030238916 16226 0x556859afca00 INFO GST_ELEMENT_PADS gstelement.c:789:gst_element_remove_pad:<nvstreammux0> removing pad 'src'
0:00:00.030253743 16226 0x556859afca00 INFO GST_REFCOUNTING gstelement.c:3297:gst_element_dispose:<nvstreammux0> 0x556859dda140 parent class dispose
0:00:00.030258418 16226 0x556859afca00 INFO GST_REFCOUNTING gstelement.c:3328:gst_element_finalize:<nvstreammux0> 0x556859dda140 finalize
0:00:00.030262512 16226 0x556859afca00 INFO GST_REFCOUNTING gstelement.c:3334:gst_element_finalize:<nvstreammux0> 0x556859dda140 finalize parent
Strangely, nvstreammux will load.
Any ideas, or a list of dependencies to install manually would be very helpful. Better yet, putting deepstream in the online apt repositories and fixing the Requires so they’re installed automatically would be very much appreciated.
