Guys,
In latest NVENC there is a new rate control mode with constant → targetQuality parameter. If this is set can we still use minqp and maxqp to hard limit the internal qp min and max values ?
Guys,
Topic | Replies | Views | Activity | |
what is constant qp in nvenc? | 2 | 8654 | December 22, 2017 | |
NvEnc with variable bandwidth? | 0 | 224 | April 2, 2024 | |
NEVNC HEVC "Highest Performance" Settings | 1 | 1030 | October 5, 2018 | |
Why using nvenc av1 encoding to set minqp and maxqp to change the picture quality does not work? | 0 | 453 | November 1, 2023 | |
in nvenc_hevc encoder using constant bitrate mode | 1 | 1138 | February 22, 2018 | |
Is it possible to dynamically change the targetQuality using nvEncReconfigureEncoder? | 0 | 20 | November 1, 2024 | |
NVENC can't reach the target bitrate I set | 3 | 1525 | October 12, 2021 | |
NvEnc: Multirate encoding? | 0 | 509 | October 5, 2021 | |
How to adjust current nvenc max rate | 4 | 776 | October 18, 2021 | |
NVENC/H265 return of performance on 7th generation? | 0 | 1165 | November 18, 2020 |
