Nvethernet 2490000.ethernet eth0: Link is Down
Two devices (xavier nx) are connected to the same PC via a network cable, and transmit a small amount of data.After five or six days of measurement, Xavier NX eth0 reported an anomaly at the same time.The information for one of the devices is as follows:
Dec 24 10:43:44 tegra-ubuntu kernel: [514835.264882] nvethernet 2490000.ethernet eth0: Link is Down
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.1176] device (eth0): state change: activated -> unavailable (reason 'carrier-changed', sys-iface-state: 'managed')
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.1525] manager: NetworkManager state is now DISCONNECTED
Dec 24 10:43:50 tegra-ubuntu dbus-daemon[371]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.3' (uid=0 pid=381 comm="/usr/sbin/NetworkManager --no-daemon " label="kernel")
Dec 24 10:43:50 tegra-ubuntu systemd[1]: Starting Network Manager Script Dispatcher Service...
Dec 24 10:43:50 tegra-ubuntu dbus-daemon[371]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Dec 24 10:43:50 tegra-ubuntu systemd[1]: Started Network Manager Script Dispatcher Service.
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2570] device (eth0): carrier: link connected
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2581] device (eth0): state change: unavailable -> disconnected (reason 'carrier-changed', sys-iface-state: 'managed')
Dec 24 10:43:50 tegra-ubuntu kernel: [514841.409014] nvethernet 2490000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2614] policy: auto-activating connection 'netplan-eth0' (626dd384-8b3d-3690-9511-192b2c79b3fd)
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2638] device (eth0): Activation: starting connection 'netplan-eth0' (626dd384-8b3d-3690-9511-192b2c79b3fd)
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2644] device (eth0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2663] manager: NetworkManager state is now CONNECTING
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2684] device (eth0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2708] device (eth0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2760] device (eth0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2837] device (eth0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2850] device (eth0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2870] manager: NetworkManager state is now CONNECTED_LOCAL
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2924] manager: NetworkManager state is now CONNECTED_SITE
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2930] policy: set 'netplan-eth0' (eth0) as default for IPv4 routing and DNS
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2950] device (eth0): Activation: successful, device activated.
Dec 24 10:43:50 tegra-ubuntu NetworkManager[381]: <info>  [1703414630.2978] manager: NetworkManager state is now CONNECTED_GLOBAL
Dec 24 10:44:00 tegra-ubuntu systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Dec 24 10:44:16 tegra-ubuntu kernel: [514868.032881] nvethernet 2490000.ethernet eth0: Link is Down
Dec 24 10:44:19 tegra-ubuntu NetworkManager[381]: <info>  [1703414659.9530] device (eth0): carrier: link connected
Dec 24 10:44:19 tegra-ubuntu kernel: [514871.104995] nvethernet 2490000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
For information, do you use latest Jetpack 5.1.2? We suggest use latest version since certain issues are fixed in later releases.
