Hi all,
this is probably a different incarnation of TPR #27323, but I wanted to report it nevertheless. The problem appears if a contained subroutine/function in a subroutine or function local to a submodule (i.e. not being a module subroutine) tries to modify private components of a UDT defined within the submodule’s module. This triggers the error (me referring to 22.3-0 on x86-64 Linux):
NVFORTRAN-S-0155-Attempt to use private component: p (permutations.f90: 32)
0 inform, 0 warnings, 1 severes, 0 fatal for insert
for the simple example:
module m
implicit none
private
public :: t1
type :: t1
private
integer :: p
end type t1
interface
module subroutine s1 ()
end subroutine s1
end interface
end module m
submodule (m) m_s
implicit none
contains
end subroutine s1
subroutine s2 (pa)
type(t1), dimension(:), intent(inout) :: pa
contains
subroutine insert (p)
type(t1), intent(inout) :: p
p%p = 0
end subroutine insert
end subroutine s2
end submodule m_s
