If a derived type with defined is part of an other derived type, the assignment of the wrapping type does not trigger the user defined assignment of the contained type. The code below should trigger the user defined assignment and print 41 at the end, but it fails to do so.
module testmod
implicit none
! Wrapping everything dirty (needing user defined assignment into a special type)
type :: dirty_t
integer :: val = -1
contains
procedure :: dirty_assign
generic :: assignment(=) => dirty_assign
end type dirty_t
! Extends abstract interface
type :: container_t
type(dirty_t) :: dirty
end type container_t
contains
subroutine dirty_assign(this, other)
class(dirty_t), intent(out) :: this
type(dirty_t), intent(in) :: other
this%val = other%val - 1
print "(a, i0, a, i0, a)", "dirty_assign (", other%val, " -> ", this%val, ")"
end subroutine dirty_assign
end module testmod
program testprog
use testmod
implicit none
type(container_t), allocatable :: stat1, stat2
class(container_t), allocatable :: dyn
allocate(stat1)
stat1%dirty%val = 42
stat2 = stat1
print "(a, i0)", "stat2 value: ", stat2%dirty%val
dyn = stat2
print "(a, i0)", "dyn value: ", dyn%dirty%val
end program testprog
See also some more details on the topic at
