Nvfortran25 fails with polymorphic pointer , Illegal POINTER assignment
I am compiling a fortran code with nvfortran.
The compiler version I am using is:
nvfortran 25.1-0 64-bit target on x86-64 Linux -tp cascadelake
I use iso_c_binding with a polymorphic pointer: The code compiles and run in gfortran and intel fortran, but fails with type mismatch error in nvfortran.
Here is a sample code which reproduces the error:
program sample
use iso_c_binding
type mytype
class(*), pointer :: anyptr => null()
endtype mytype
type(mytype) :: myobj
type(c_funptr), pointer  :: ptrval
!integer, pointer :: ptrval
!real, pointer :: ptrval
ptrval => myobj%anyptr
endprogram sample
nvfortran sample.f90 gives me the error:
NVFORTRAN-S-0155-Illegal POINTER assignment - type mismatch (sample.f90: 11)
0 inform, 0 warnings, 1 severes, 0 fatal for sample
Pointer of any other type also gives the same error. I tried the commented lines, integer and real pointer types, as well.
Hi rajany.kv,
Thanks for the report and great reproducing example. I’ve confirmed that it’s a compiler issue so filed a report, TPR #37205, and sent it engineering for investigation.
-Mat
Hi rajany.kv,
Engineering just let me know that TPR#37205 was fixed in our 25.5 release.
-Mat
