I’m installing NVIDIA GPU driver v.319.32 (for my PNY K20c GPU) under OpenSUSE 12.3 (kernel 3.7.10).
The necessary steps for removing of nouveau driver were performed, and nouveau kernel module isn’t loaded.
But compilation of kernel interface of nvidia.ko(via standard NVIDIA-Linux-x86_319/32.run execution) gives an error:
----------------(from nvidia-installer log)---------------------------
KBUILD_SRC=/usr/src/linux-3.7.10-1.1
KBUILD_EXTMOD=“/tmp/selfgz1723/NVIDIA-Linux-x86_64-319.32/kernel” -f /usr/src/linux-3.7.10-1.1/Makefile
modules
test -e include/generated/autoconf.h -a -e include/config/auto.conf || (
echo >&2;
echo >&2 " ERROR: Kernel configuration is invalid.“;
echo >&2 " include/generated/autoconf.h or include/config/auto.conf are missing.”;
echo >&2 " Run ‘make oldconfig && make prepare’ on kernel src to fix it.";
echo >&2 ;
/bin/false)
But both files are presented, and kernel preparation steps ( make oldconfig && make prepare) were executed successfully.
But then in nvidia-installer.log I see compilation steps w/warnings ( and I beleive that
nvidia.ko was built.) After that I see messages
--------------------------from nvidia-installer.log ----------------------------------
NVIDIA: left KBUILD.
→ done.
→ Kernel module compilation complete.
→ Unable to determine if Secure Boot is enabled: No such file or directory
ERROR: Unable to load the kernel module ‘nvidia.ko’. …
Then nvidia-installer.log contains also kernel messages:
→ Kernel module load error: No such device
→ Kernel messages:
…[ 25.286079] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 1379.760532] nvidia: module license ‘NVIDIA’ taints kernel.
[ 1379.760536] Disabling lock debugging due to kernel taint
[ 1379.765158] nvidia 0000:01:00.0: enabling device (0140 → 0142)
[ 1379.765165] NVRM: This PCI I/O region assigned to your NVIDIA device is invalid:
[ 1379.765165] NVRM: BAR1 is 0M @ 0x0 (PCI:0000:01:00.0)
[ 1379.765166] NVRM: The system BIOS may have misconfigured your GPU.
[ 1379.765169] nvidia: probe of 0000:01:00.0 failed with error -1
[ 1379.765177] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 1379.765178] NVRM: None of the NVIDIA graphics adapters were initialized!
It looks as BIOS setting problem, but the corresponding (by my opinion) parameter in
BIOS Advanced/PСI, PCI-E submenu - “Above 4G Decoding” - is Enabled.
I’m also afraid some kernel messages from /var/log/messages
-----------------------from /var/log/messages------
2013-07-04T01:43:43.666022+04:00 c6ws4 kernel: [ 0.421559] pci 0000:00:01.0: BAR 15: can’t assign mem pref (size 0x18000000)
2013-07-04T01:43:43.666024+04:00 c6ws4 kernel: [ 0.421563] pci 0000:00:01.0: BAR 14: assigned [mem 0xe1000000-0xe1ffffff]
2013-07-04T01:43:43.666025+04:00 c6ws4 kernel: [ 0.421566] pci 0000:00:16.1: BAR 0: assigned [mem 0xe0001000-0xe000100f 64bit]
2013-07-04T01:43:43.666026+04:00 c6ws4 kernel: [ 0.421576] pci 0000:01:00.0: BAR 1: can’t assign mem pref (size 0x10000000)
2013-07-04T01:43:43.666027+04:00 c6ws4 kernel: [ 0.421579] pci 0000:01:00.0: BAR 3: can’t assign mem pref (size 0x2000000)
2013-07-04T01:43:43.666027+04:00 c6ws4 kernel: [ 0.421581] pci 0000:01:00.0: BAR 0: assigned [mem 0xe1000000-0xe1ffffff]
2013-07-04T01:43:43.666028+04:00 c6ws4 kernel: [ 0.421584] pci 0000:01:00.0: BAR 6: can’t assign mem pref (size 0x80000)
2013-07-04T01:43:43.666029+04:00 c6ws4 kernel: [ 0.421586] pci 0000:00:01.0: PCI bridge to [bus 01]
The question is: is there some NVIDIA driver problems - or it’s hardware PCI problems in my Supermicro X9SCI/X9SCA motherboard (BIOS version is 2.0a) ?
Mikhail
