I want to enable PCIe gen3 operation by using NVreg_EnablePCIeGen3 module parameter. Adding the line
options nvidia_367 NVreg_EnablePCIeGen3=1
to a separate file(named nvidia-gen3.conf) in /etc/modprobe.d directory usually worked(for previous driver versions). But sometimes (and in case of 367.18) the option seems to be ignored at boot. If I do the modprobe manually after boot(previously switching to VT console and rmmod all nvidia modules), everything is OK: nvidia-settings and nvidia-smi report PCI gen3 is enabled, modprobe -v adds module parameter on insert, but systool -vm nvidia still shows no parameters.(maybe module bug?) With the same file present in /etc/modprobe.d I get only PCIe gen2 after boot according to nvidia-settings at least. Is there some stable solution for this? Maybe some other module alias exists(tried nvidia and nvidia-current - no luck)? Or maybe there’s some conflct with nvidia-graphics-drivers.conf in /etc/modprobe.d: for example module alias is added sometimes after my option? BTW adding kernel parameter nvidia.NVreg_EnablePCIeGen3=1 before boot seems to also not work…
Installed nvidia beta driver from ubuntu graphics-drivers PPA.
