NVIDIA 560 Beta OFFLINE README
Hello guys, I made an offline copy of the Nvidia 560 Beta README file, because I like to have it stored locally as opposed to having to be connected to the internet persistently, so I thought I would share it with you guys.
Nvidia_560_offline_readme.gz (1.1 MB)
I also put it on this filebin… I don’t even know, how do you upload a simple file to the internet, without all these paywall websites getting in the way.
and I even made source notes… with more information
about the driver, and how I created an offline copy of the readme…
# August 7, 2024
# This is the source info for the offline nvidia 560 driver readme.
# Nvidia 560 beta driver (open source)
# The run file (installer) is here.
https://www.nvidia.com/Download/driverResults.aspx/230588/en-us/
# The source for it's modules are here, for custom builds
https://github.com/NVIDIA/open-gpu-kernel-modules
# Nvidia 560 beta driver README
# The readme is only available in an online format,
# so I used wget to make an offline copy,
# so it can be stored on the local system,
# and read freely.
# The url of the readme
us.download.nvidia.com/XFree86/Linux-x86_64/560.31.02/README/index.html
# the wget command I used to create an offline copy
# i had to use ignore robots, and remove the https://
# protocol bit from the url, to make this work.
wget -mkEpnp -erobots=off us.download.nvidia.com/XFree86/Linux-x86_64/560.31.02/README/index.html
# how to make an offline mirror(copy) of a website using wget
Make Offline Mirror of a Site using `wget`
Sometimes you want to create an offline copy of a site that you can take and view even without internet access. Using wget you can make such copy easily:
wget --mirror --convert-links --adjust-extension --page-requisites
--no-parent -erobots=off http://example.org
Explanation of the various flags:
    --mirror – Makes (among other things) the download recursive.
    --convert-links – convert all the links (also to stuff like CSS stylesheets) to relative, so it will be suitable for offline viewing.
    --adjust-extension – Adds suitable extensions to filenames (html or css) depending on their content-type.
    --page-requisites – Download things like CSS style-sheets and images required to properly display the page offline.
    --no-parent – When recursing do not ascend to the parent directory. It useful for restricting the download to only a portion of the site.
    -erobots=off (ignore robots.txt that tells web crawlers to ignore web pages)
# How to use the offline readme
# use the index.html file within the directories, and drag it,
# into a web browsers url box, or type in the location of the index.html
# file into a url box to open up the offline readme.
# like this..
/Nvidia_560_Readme/us.download.nvidia.com/XFree86/Linux-x86_64/560.31.02/README/index.html
