Nvidia APT Repos Down (1+ weeks)
https://repo.download.nvidia.com/jetson/ for all suites (t210, common, etc) has been down for r32 dist (used for 32.3.1) for over a week now. The packages remain in the pool but InRelease and Release for this dist is missing so using apt results in an error.
This has happened before and never been corrected with earlier releases as well.
Please correct this issue and prevent it from happening in the future.
We will check it. Sorry for the inconvenience.
We can access the package:
https://repo.download.nvidia.com/jetson/t210/pool/main/n/nvidia-l4t-3d-core/nvidia-l4t-3d-core_32.3.1-20191209225816_arm64.deb
Please check if you can download it.
Please read the original post again…
Regardless I will teach you how an apt repo works. 32.3.1 BSP uses the r32 dist. The Release file for that has gone missing (along with the Packages files, etc).
see that r32.3.1 which uses the r32 dist is not online https://repo.download.nvidia.com/jetson/t210/dists/r32/Release
r32.7.4 which uses the r32.7 dist is still online https://repo.download.nvidia.com/jetson/t210/dists/r32.7/Release
If you don’t understand that is fine, just report this to your developers and they will understand and notice the issue immediately.
We will check it. Would suggest use the latest Jetpack 4 release.
For debug purposes consider using a web browser to the repo. Those repositories are just web pages. This implies that other web issues can get in the way, such as DNS or routing, and seeing what a web browser responds with can give clues as to the actual cause.
Nvidia developers corrected this issue with missing Release, InRelease, main/binary-arm64/Packages and other apt repo contents for the r32 dist within the past 6hrs.
Thank you
