Having issue with 64-bit Linux Mint 20.1, Cinnamon and OBS 26.1.1. Some windows with XComposite are black (desktop, web browser Brave, Chromium, etc.), some visible (terminal, Thunderbird, System settings, file manager, etc.). At the same time desktop with XHSM is working fine.
Having nVidia Quadro M2000M (GM107GLM). Allow flipping is disabled - didn’t help. Also that alpha channel Mesa solution option under XComposite settings didn’t help.
nvidia-xconfig --composite
didn’t help either :(
$ inxi -xxxG
Graphics:
Device-1: NVIDIA GM107GLM [Quadro M2000M] vendor: Lenovo driver: nvidia v: 460.39
bus ID: 01:00.0 chip ID: 10de:13b0
Display: x11 server: X.Org 1.20.9 driver: nvidia
unloaded: fbdev,modesetting,nouveau,vesa resolution: 2560x1440~60Hz
OpenGL: renderer: Quadro M2000M/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39 direct render: Yes
$ nvidia-smi
| NVIDIA-SMI 460.39 Driver Version: 460.39 CUDA Version: 11.2 |
| | | MIG M. |
| 0 Quadro M2000M Off | 00000000:01:00.0 On | N/A |
| N/A 44C P8 N/A / N/A | 394MiB / 4035MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 18890 G /usr/lib/xorg/Xorg 186MiB |
| 0 N/A N/A 19251 G cinnamon 38MiB |
| 0 N/A N/A 19655 G ...gAAAAAAAAA --shared-files 12MiB |
| 0 N/A N/A 19806 G ...AAAAAAAAA= --shared-files 14MiB |
| 0 N/A N/A 19910 G ...96AB038DB6D131158B746C3CC 3MiB |
| 0 N/A N/A 20058 G ...token=1743612660864995289 12MiB |
| 0 N/A N/A 26848 G ...AAAAAAAAA= --shared-files 114MiB |
Another similar issue:
This issue is outlined in detail over in GitHub in this issue: Black preview screen in Linux Mint · Issue #4259 · obsproject/obs-studio · GitHub
It seems like many users are experiencing this issue, But the TL;DR:
Having a nVIDIA Ge Force 1080Ti with the latest drivers (460) and when I load OBS (v26.1.1) a black screen appears with no preview available (screenshot linked below).
None of the steps mentioned in the issue work. Is there a way to fix this? If not, is this a known bug that’s being worked on? Seems like it was a known issue here but the fix doesn’t seem to have helped all cards: NVIDIA DRIVERS Linux Display Driver - x86
Screenshot: https://obsproject.com/forum/attachments/screenshot-from-2021-02-17-21-31-51-png.67703/
