Hi @AastaLLL,
Thanks for responding. I changed the Dockerfile as you indicated. But it issued the same problem:
$ sudo docker build -t devicequery .
Sending build context to Docker daemon 214.2MB
Step 1/6 : FROM nvcr.io/nvidia/l4t-base:r32.4.3
---> c93fc89026d9
Step 2/6 : RUN apt-get update && apt-get install -y --no-install-recommends make g++
---> Running in a0318d71e788
OCI runtime create failed: container_linux.go:349: starting container process caused "process_linux.go:449: container init caused \"process_linux.go:432: running prestart hook 1 caused \\\"error running hook: exit status 1, stdout: , stderr: nvidia-container-cli: initialization error: driver error: failed to process request\\\\n\\\"\"": unknown
