"docker: Error response from daemon: could not select device driver “” with capabilities: [[gpu]]
On my Jetson Nano, trying to run a CUDA capable docker image is giving an error like "docker: Error response from daemon: could not select device driver “” with capabilities: [[gpu]].
ERRO[0000] error waiting for container: context canceled
Please let me know the suitable options / resolution to this problem.
Please use the image that supports l4t environment:
If you are using the older Jetpack rather than 4.4DP, please make sure you download the corresponding version:
