i have a NANO flashed with jetpack4.5.1. i want to deploy docker on this NANO.
when i run command : sudo docker run --rm --gpus all nvidia/cuda-arm64:11.0-base-ubuntu18.04 nvidia-smi
i got the err response below, how to fix it ?
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused “process_linux.go:449: container init caused “process_linux.go:432: running prestart hook 0 caused \“error running hook: exit status 1, stdout: , stderr: exec command: [/usr/bin/nvidia-container-cli --load-kmods configure --ldconfig=@/sbin/ldconfig.real --device=all --compute --utility --require=cuda>=11.0 --pid=8905 /var/lib/docker/overlay2/5b52afab74778a7cad19616a5ab802fb96641614a0e01338b836f70c5ea22d68/merged]\\nnvidia-container-cli: requirement error: unsatisfied condition: cuda >= 11.0\\n\”””: unknown.
Hello @weifeng19xx
In my opinion, this may cause different CUDA version. Is your CUDA version is 11.0?
If you use JetPack’s current CUDA packages, you can use 10.2 version in docker.
Regards
You will need to use L4T based container on the Jetson Nano:
