At this time, there is no Yocto recipe for bitbaking nvidia-container-runtime into a Yocto build. I’ve tried installing the .deb packages from the NVIDIA SDK-manager but this is apparently not enough to get the GPU access through to the containers, as running any CUDA-10 example in a docker container running nvidia-container-runtime will result in an error stating that no CUDA ready devices were found. Running an example outside of the container runs without problems.
Looking in the rootfs the default Nvidia Ubuntu that is created from the SDK-manager, i can see there is a lot of libraries and configurations that is not available in Yocto. Specifically I’ve come across the csv files in /etc/nvidia-container-runtime/host-files-for-container.d/. This looks promising as they list a ton of stuff that are merged into a container that is run with nvidia-container-runtime.
Only the l4t.csv file contains several “not found” files. As many as possible were installed through Yocto recipes, but a lot of them are still lacking and not supported in Yocto. Instead, the missing files that could not be provided from Yocto were removed from the list, one by one. Eventually though, the error received when trying to run the docker with nvidia-container-runtime is:
$ docker run -it --rm --runtime nvidia --gpus all nvcr.io/nvidia/l4t-base:r32.3.1
docker: Error response from daemon: OCI runtime create failed: container_linux.go:345: starting container process caused "process_linux.go:430: container init caused \"process_linux.go:413: running prestart hook 0 caused \\\"error running hook: exit status 1, stdout: src: /usr/lib/libcudnn.so.7, src_lnk: libcudnn.so.7.6.3, dst: /var/lib/docker/overlay2/9b07e768b59dce6c3cd1b3b94a8019978b9bc24d84511bd37d82679efc94b829/merged/usr/lib/libcudnn.so.7, dst_lnk: libcudnn.so.7.6.3\\\\nsrc: /usr/lib/libnvcaffe_parser.so.6, src_lnk: libnvparsers.so.6.0.1, dst: /var/lib/docker/overlay2/9b07e768b59dce6c3cd1b3b94a8019978b9bc24d84511bd37d82679efc94b829/merged/usr/lib/libnvcaffe_parser.so.6, dst_lnk: libnvparsers.so.6.0.1\\\\nsrc: /usr/lib/libnvcaffe_parser.so.6.0.1, src_lnk: libnvparsers.so.6.0.1, dst: /var/lib/docker/overlay2/9b07e768b59dce6c3cd1b3b94a8019978b9bc24d84511bd37d82679efc94b829/merged/usr/lib/libnvcaffe_parser.so.6.0.1, dst_lnk: libnvparsers.so.6.0.1\\\\nsrc: /usr/lib/libnvinfer.so.6, src_lnk: libnvinfer.so.6.0.1, dst: /var/lib/docker/overlay2/9b07e768b59dce6c3cd1b3b94a8019978b9bc24d84511bd37d82679efc94b829/merged/usr/lib/libnvinfer.so.6, dst_lnk: libnvinfer.so.6.0.1\\\\nsrc: /usr/lib/libnvinfer_plugin.so.6, src_lnk: libnvinfer_plugin.so.6.0.1, dst: /var/lib/docker/overlay2/9b07e768b59dce6c3cd1b3b94a8019978b9bc24d84511bd37d82679efc94b829/merged/usr/lib/libnvinfer_plugin.so.6, dst_lnk: libnvinfer_plugin.so.6.0.1\\\\nsrc: /usr/lib/libnvonnxparser.so.6, src_lnk: libnvonnxparser.so.6.0.1, dst: /var/lib/docker/overlay2/9b07e768b59dce6c3cd1b3b94a8019978b9bc24d84511bd37d82679efc94b829/merged/usr/lib/libnvonnxparser.so.6, dst_lnk: libnvonnxparser.so.6.0.1\\\\nsrc: /usr/lib/libnvonnxparser_runtime.so.6, src_lnk: libnvonnxparser_runtime.so.6.0.1, dst: /var/lib/docker/overlay2/9b07e768b59dce6c3cd1b3b94a8019978b9bc24d84511bd37d82679efc94b829/merged/usr/lib/libnvonnxparser_runtime.so.6, dst_lnk: libnvonnxparser_runtime.so.6.0.1\\\\nsrc: /usr/lib/libnvparsers.so.6, src_lnk: libnvparsers.so.6.0.1, dst: /var/lib/docker/overlay2/9b07e768b59dce6c3cd1b3b94a8019978b9bc24d84511bd37d82679efc94b829/merged/usr/lib/libnvparsers.so.6, dst_lnk: libnvparsers.so.6.0.1\\\\n, stderr: exec command: [/usr/bin/nvidia-container-cli --load-kmods configure --ldconfig=@/sbin/ldconfig.real --device=all --compute --compat32 --graphics --utility --video --display --pid=6358 /var/lib/docker/overlay2/9b07e768b59dce6c3cd1b3b94a8019978b9bc24d84511bd37d82679efc94b829/merged]\\\\nnvidia-container-cli: mount error: (null)\\\\n\\\"\"": unknown.
ERRO[0003] error waiting for container: context cancelled
“nvidia-container-cli: mount error: (null)” is an error i cannot seem to figure out how to solve.
Below are information from the build
OS INFO:
Linux jetson-nano 4.9.140-l4t-r32.3.1+g47e7e1c #1 SMP PREEMPT Mon Jan 20 08:52:22 UTC 2020 aarch64 aarch64 aarch64 GNU/Linux
YOCTO INFO:
Yocto/poky zeus r32.3.1 (JetPack 4.3)
CUDA INFO:
$ dpkg --get-selections | grep cuda
ii cuda-command-line-tools 10.0.326-1-r0 arm64 cuda-command-line-tools version 10.0.326-1-r0
ii cuda-command-line-tools-libnvtoolsext 10.0.326-1-r0 arm64 cuda-command-line-tools version 10.0.326-1-r0
ii cuda-core 10.0.326-1-r0 arm64 cuda-core version 10.0.326-1-r0
ii cuda-cublas 10.0.326-1-r0 arm64 cuda-cublas version 10.0.326-1-r0
ii cuda-cudart 10.0.326-1-r0 arm64 cuda-cudart version 10.0.326-1-r0
ii cuda-cufft 10.0.326-1-r0 arm64 cuda-cufft version 10.0.326-1-r0
ii cuda-curand 10.0.326-1-r0 arm64 cuda-curand version 10.0.326-1-r0
ii cuda-cusolver 10.0.326-1-r0 arm64 cuda-cusolver version 10.0.326-1-r0
ii cuda-cusparse 10.0.326-1-r0 arm64 cuda-cusparse version 10.0.326-1-r0
ii cuda-driver 10.0.326-1-r0 arm64 cuda-driver version 10.0.326-1-r0
ii cuda-misc-headers 10.0.326-1-r0 arm64 cuda-misc-headers version 10.0.326-1-r0
ii cuda-npp 10.0.326-1-r0 arm64 cuda-npp version 10.0.326-1-r0
ii cuda-nvrtc 10.0.326-1-r0 arm64 cuda-nvrtc version 10.0.326-1-r0
ii cuda-toolkit 10.0.326-1-r0 arm64 cuda-toolkit version 10.0.326-1-r0
$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "NVIDIA Tegra X1"
CUDA Driver Version / Runtime Version 10.0 / 10.0
CUDA Capability Major/Minor version number: 5.3
Total amount of global memory: 3964 MBytes (4156665856 bytes)
( 1) Multiprocessors, (128) CUDA Cores/MP: 128 CUDA Cores
GPU Max Clock rate: 922 MHz (0.92 GHz)
Memory Clock rate: 1600 Mhz
Memory Bus Width: 64-bit
L2 Cache Size: 262144 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65536), 3D=(4096, 4096, 4096)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (2147483647, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 1 copy engine(s)
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: Yes
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device supports Compute Preemption: No
Supports Cooperative Kernel Launch: No
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 0 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 10.0, CUDA Runtime Version = 10.0, NumDevs = 1
Result = PASS
DOCKER INFO:
$ docker info
Client:
Debug Mode: false
Server:
Containers: 0
Running: 0
Paused: 0
Stopped: 0
Images: 1
Server Version: 19.03.2-ce
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: true
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
Volume: local
Network: bridge host ipvlan macvlan null overlay
Log: awslogs fluentd gcplogs gelf journald json-file local logentries splunk syslog
Swarm: inactive
Runtimes: nvidia runc
Default Runtime: nvidia
Init Binary: docker-init
containerd version: fd103cb716352c7e19768e4fed057f71d68902a0.m
runc version: 425e105d5a03fabd737a126ad93d62a9eeede87f-dirty
init version: fec3683-dirty (expected: fec3683b971d9)
Kernel Version: 4.9.140-l4t-r32.3.1+g47e7e1c
OSType: linux
Architecture: aarch64
CPUs: 4
Total Memory: 3.871GiB
Docker Root Dir: /var/lib/docker
Debug Mode: false
Registry: https://index.docker.io/v1/
Labels:
Experimental: false
Insecure Registries:
localhost:5000
127.0.0.0/8
Registry Mirrors:
http://localhost:5000/
Live Restore Enabled: false
NVIDIA-CONTAINER-RUNTIME INFO:
ii libnvidia-container-tools 0.9.0~beta.1 arm64 NVIDIA container runtime library (command-line tools)
ii libnvidia-container0:arm64 0.9.0~beta.1 arm64 NVIDIA container runtime library
ii libnvidia-egl-wayland1 1.1.3-r0 arm64 egl-wayland version 1.1.3-r0
ii nvidia-container-runtime 3.1.0-1 arm64 NVIDIA container runtime
un nvidia-container-runtime-hook <none> <none> (no description available)
ii nvidia-container-toolkit 1.0.1-1 arm64 NVIDIA container runtime hook
ii xserver-xorg-video-nvidia 32.3.1-r0 arm64 xserver-xorg-video-nvidia version 32.3.1-r0
I am stuck in getting this to work as I’ve tried almost anything I can think of. Does anyone know anything about getting Nvidia-container-runtime to work with Yocto?
