Nvidia Control Panel not available in the system - Ref# 3999308 - BUG Fix
Hi everyone,
I wanted to bring attention to the document linked below:
NVIDIA Control Panel not found on system
Could someone please provide an update on when the fix for this bug will be available?
Thank you.
Vinil
Hi @Vinil-Vadakkepurakkal,
I will move this post over to the vGPU category for visibility.
But as far as I could find out internally you will need to follow the workaround described in the link you shared.
The bug itself is still work in progress.
NVCPL can be downloaded as separate software package from our licensing portal. That should fix the issue.
Hello we are using Nvidia as part of our Azure Infrastructure and therefore do not have direct licensing with NVIDIA. Do we need this to download the NVCPL as an MSI / non store app?
Can be this be made available to us currently we only have the store app here: Azure N-series NVIDIA GPU driver setup for Windows - Azure Virtual Machines | Microsoft Learn)
