I have quite a strange problem with nvidia on linux. I wanted to believe it was an accident, but it happened twice…
I have a lenovo P50 laptop with two graphic devices :
intel chipset
NVIDIA Quadro M2000M
I have 3 bootable partitions with 3 OS :
ubuntu studio for live performance (21.10)
ubuntu “classic” for everyday usage (20.04)
windows 10
In ubuntu studio I need nvidia driver, after install I launch :
ubuntu-drivers autoinstall
reboot
What happens :
ubuntu studio with nvidia driver works fine during days. I did not apply any update on this OS.
I use the other OS (ubuntu classic and windows, with maybe system updates on thoses)
when I come back to ubuntu studio after a few days… nvidia is gone !
lspci shows no nvidia device
lsmod shows no nvidia module
nvidia-settings : ERROR: Unable to load info from any available system + empty app
nvidia-driver package is still installed
The first time I reinstalled ubuntu studio from scrach.
The second time I managed to recover nvidia with following commands :
rm /etc/X11/xorg.conf
apt install --reinstall nvidia-prime
prime-select nvidia
sudo update-initramfs -u
reboot
# no nvidia at boot
apt remove nvidia-driver*
reboot
# nvidia at boot !
I wonder if the “classic” ubuntu updates could mess with grub and have an effect on my ubuntu studio ? I tried to launch “os-prober; update-grub” on classic ubuntu to reproduce the case, but nvidia was still OK on ubuntu studio.
I am not able to make it malfunction, as I don’t understand the problem… and it can take weeks for the problem to come back… But I will come here and post when it happens !
Something went terribly wrong with the last update.
avril 03 13:09:22 ubstud kernel: NVRM: API mismatch: the client has the version 470.103.01, but
NVRM: this kernel module has the version 470.86. Please
NVRM: make sure that this kernel module and all NVIDIA driver
NVRM: components have the same version.
Is the last sign of the driver trying to load.
Take a look at the output (and maybe paste it here) of dkms status, for which kernels the driver is installed (if it says added, that’s not enough).
Make sure you have the kernel headers for your running kernel installed. Usually named like: linux-headers-$(uname -r). Because there is no sign of the driver module compiling.
When installing a new version of the nvidia driver, all driver modules from all installed kernel versions get removed. And usually only get installed for the currently running kernel.
I don’t know why the driver didn’t get installed though you have the headers installed.
Any reason you run 5.13.0-22 and not 5.13.0-39?
dpkg -l |grep nvidia
ii libnvidia-cfg1-470:amd64 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-470 470.103.01-0ubuntu0.21.10.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-470:amd64 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-470:i386 470.103.01-0ubuntu0.21.10.1 i386 NVIDIA libcompute package
ii libnvidia-decode-470:amd64 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-470:i386 470.103.01-0ubuntu0.21.10.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.7-2build1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-470:amd64 470.103.01-0ubuntu0.21.10.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-470:i386 470.103.01-0ubuntu0.21.10.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-470:amd64 470.103.01-0ubuntu0.21.10.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-470:amd64 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-470:i386 470.103.01-0ubuntu0.21.10.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-470:amd64 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-470:i386 470.103.01-0ubuntu0.21.10.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-ifr1-470:amd64 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA OpenGL-based Inband Frame Readback runtime library
ii libnvidia-ifr1-470:i386 470.103.01-0ubuntu0.21.10.1 i386 NVIDIA OpenGL-based Inband Frame Readback runtime library
rc linux-modules-nvidia-470-5.13.0-21-lowlatency 5.13.0-21.21+1 amd64 Linux kernel nvidia modules for version 5.13.0-21
rc linux-modules-nvidia-470-5.13.0-22-lowlatency 5.13.0-22.22+2 amd64 Linux kernel nvidia modules for version 5.13.0-22
ii linux-modules-nvidia-470-5.13.0-39-lowlatency 5.13.0-39.44 amd64 Linux kernel nvidia modules for version 5.13.0-39
ii linux-modules-nvidia-470-lowlatency 5.13.0-39.44 amd64 Extra drivers for nvidia-470 for the lowlatency flavour
rc linux-objects-nvidia-470-5.13.0-21-lowlatency 5.13.0-21.21+1 amd64 Linux kernel nvidia modules for version 5.13.0-21 (objects)
ii linux-objects-nvidia-470-5.13.0-22-lowlatency 5.13.0-22.22+2 amd64 Linux kernel nvidia modules for version 5.13.0-22 (objects)
ii linux-objects-nvidia-470-5.13.0-39-lowlatency 5.13.0-39.44 amd64 Linux kernel nvidia modules for version 5.13.0-39 (objects)
ii linux-signatures-nvidia-5.13.0-22-lowlatency 5.13.0-22.22+2 amd64 Linux kernel signatures for nvidia modules for version 5.13.0-22-lowlatency
ii linux-signatures-nvidia-5.13.0-39-lowlatency 5.13.0-39.44 amd64 Linux kernel signatures for nvidia modules for version 5.13.0-39-lowlatency
ii nvidia-compute-utils-470 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA compute utilities
ii nvidia-driver-470 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA driver metapackage
ii nvidia-kernel-common-470 470.103.01-0ubuntu0.21.10.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-470 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 470.57.01-0ubuntu3.1~0.21.10.1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-470 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.1 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-470 470.103.01-0ubuntu0.21.10.1 amd64 NVIDIA binary Xorg driver
It seems there is something more for 5.13.0-39 compared to -22 :
# dpkg -l |grep nvidia | grep 5.13.0-22
# dpkg -l |grep nvidia | grep 5.13.0-39
No…
ubuntu studio for live performance (21.10) (where this problem occurs since update)
windows 10
In grub.cfg I can see the following “menuentry” item :
/boot/vmlinuz-5.13.0-39-lowlatency # ubuntu studio, march 2022
/boot/vmlinuz-5.13.0-30-lowlatency # ubuntu studio, feb 2022
/boot/vmlinuz-5.13.0-22-lowlatency # ubuntu studio, november 2021
/EFI/Microsoft/Boot/bootmgfw.efi # windows
/boot/vmlinuz-5.11.0-46-generic # other ubuntu install
/boot/vmlinuz-5.11.0-44-generic # other ubuntu install
But when I really come to grub screen on boot, the only choice I have for ubuntu studio is :
5.13.0-22
5.13.0-21 (no more installed : if I choose this the boot fails)
I suspect I may have a problem with grub update during system update, something like “ubuntu studio lets the other ubuntu install deal with grub”…
and… nothing changed in the grub menu, I still have the old kernels. I guess I just did what the system update did.
I booted on the other ubuntu partition and launched the same commands, and bingo : the new kernels where detected, and now appear on boot. By default ubuntu studio boots on 5.13.0-39-lowlatency and nvidia-settings is now working.
I still do not understand exactly what happens, but it seems that only the regular ubuntu can handle grub.
ubuntu has /boot on sda7
ubuntu studio has /boot on sda8
the boot partition UEFI is on sda2
Anyway, even if you don’t have a perfect explanation for this, a big thanks for your help, I now know what to do (update-grub on the other ubutu after each update) !
