have an HP ZBook Fury G8 17,3" FHD IPS i7-11800H 128GB/2TB SSD T1200 4A698EA.
On second SSD there is Windows 10 Pro installed.
Windows can use my T1200 nvidia card without problems.
On a fresh instlled xubuntu 21.10 5.13.0-27-generic
with latest update i have the problem, that nvidia-driver did’nt load.
sudo ubuntu-drivers list
nvidia-driver-470, (kernel modules provided by linux-modules-nvidia-470-generic)
nvidia-driver-495, (kernel modules provided by linux-modules-nvidia-495-generic)
nvidia-driver-460-server, (kernel modules provided by linux-modules-nvidia-460-server-generic)
nvidia-driver-470-server, (kernel modules provided by linux-modules-nvidia-470-server-generic)
sudo ubuntu-drivers autoinstall
or
sudo apt install nvidia-driver-470
installs the software without error.
reboot
leads to an 100% core load with a proces that tried modeset with no success.
At the ent nvidia driver was’nt load.
sudo dmesg | grep -i D3cold
give me
"nvidia 0000:01:00.0: can’t change power state from D3cold to D0 (config space inaccessible) vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=none nvidia probe of 0000:01:00.0 failed with error -1 nvidia-nvlink: Unregistered the Nvlink Core, major device number 507 Nvlink Core is being initialized, major device number 507
nfo:
— lspci -v | grep VGA —
00:02.0 VGA compatible controller: Intel Corporation TigerLake-H GT1 [UHD Graphics] (rev 01) (prog-if 00 [VGA controller])
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1fbc (rev ff) (prog-if ff)
— inxi -G —
Graphics: Device-1: Intel TigerLake-H GT1 [UHD Graphics] driver: i915 v: kernel
Device-2: NVIDIA driver: N/A
Display: x11 server: X.Org 1.20.13 driver: loaded: modesetting unloaded: fbdev,vesa resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 21.2.2
— dkms status —
— prime-select query —
on-demand
— glxinfo|egrep “OpenGL vendor|OpenGL renderer*” —
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) UHD Graphics (TGL GT1)
Welcher Kernel-Modul bedient VGA ?
— lspci -nnk | grep -i vga -A3 | grep ‘in use’
Kernel driver in use: i915
Kernel driver in use: snd_hda_intel
n my opinion there are a new way how powermanagement works.
In BIOS i can only choose Hybrid Grafic or UHD, no Power-Mode.
I choosed Hybrid Grafic, because in the other case nvidia controller is not visible.
That new powermanagement did’nt allow to power on some devices (not only
grafics) from within a kernel module.
There must be an other way to do it (in Windows it works).
I think the nvidia-driver did’nt recognize the situation.
nvidia-bug-report.log.gz (39.9 KB)
test_wich_grafic_adapter_are_present.log.gz (17.8 KB)
