Nvidia Display Container seems to be crashing and affecting the Right Click menu not opening. The problem occurs when several users almost simultaneously log in to the Windows Server 2019 terminal server. But when they log in in turn (after the message “NVIDIA RTX Virtual Workstation license received” appears on each user), the right-click menu opens normally. Can you help with this?
Known issue. Are you still on 15.1? Please update to the latest…
It seems to be 15 installed. It need to consider this possibility. Now I used the ShexView utility, deactivated the Nvidia Cpl item. Now there is no Nvidia Control Panel, but it seems to Right Click works on all users. Thank you very much for your answer
NVIDIA-GRID-Windows-525.85.05-528.24
NVIDIA-SMI 528.24 Driver Version: 528.24 CUDA Version: 12.0 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 Tesla V100-PCIE… WDDM | 0000553F:00:00.0 Off | 0 |
| N/A 34C P0 23W / 250W | 648MiB / 16384MiB | 0% Default |
| | | N/A
Thank you for confirming my actions in this case. I’m going to try version 15.2 (Complete vGPU 15.2 DDA GPU driver package for Microsoft platforms) for our hypervisor Windows Hyper-V Server 2019. Thank you very much for your reply
Unfortunately, updating to version 15.2 did not resolve the issue. Therefore, I again used the ShexView utility. Maybe I’m doing something wrong
