I am trying to install cuda 11.4 on my Centos8 Stream machine but dnf errors out. I followed the tutorial and added cuda-rhel8-x86_64
repo, updated and then tried to install.
$ uname -r
4.18.0-408.el8.x86_64
$ lspci -vvv | grep Quadro
68:00.0 VGA compatible controller: NVIDIA Corporation GK110GL [Quadro K6000] (rev a1) (prog-if 00 [VGA controller])
$ sudo dnf module install nvidia-driver:470
Last metadata expiration check: 0:08:37 ago on Fri 02 Dec 2022 02:31:16 PM CET.
Error:
Problem 1: problem with installed package kernel-debug-core-4.18.0-408.el8.x86_64
- package kmod-nvidia-470.161.03-4.18.0-425.3.1-3:470.161.03-3.el8.x86_64 requires (kernel = 4.18.0-425.3.1.el8 if kernel), but none of the providers can be installed
- package nvidia-kmod-common-3:470.161.03-1.el8.noarch requires nvidia-kmod = 3:470.161.03, but none of the providers can be installed
- cannot install the best candidate for the job
- package kmod-nvidia-latest-dkms-3:470.161.03-1.el8.x86_64 is filtered out by modular filtering
Problem 2: problem with installed package kernel-debug-core-4.18.0-365.el8.x86_64
- package nvidia-driver-3:470.161.03-1.el8.x86_64 requires nvidia-kmod-common = 3:470.161.03, but none of the providers can be installed
Problem 3: problem with installed package kernel-debug-core-4.18.0-348.7.1.el8_5.x86_64
- package cuda-drivers-470.161.03-1.x86_64 requires nvidia-driver >= 3:470.161.03, but none of the providers can be installed
- package nvidia-driver-3:495.29.05-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:510.108.03-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:510.39.01-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:510.47.03-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:510.73.08-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:510.84-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:510.85.02-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:515.43.04-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:515.48.07-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:515.65.01-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:515.65.07-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:515.86.01-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-driver-3:520.61.05-1.el8.x86_64 is filtered out by modular filtering
- package xorg-x11-drv-nvidia-cuda-3:515.65.01-2.el8.x86_64 is filtered out by modular filtering
Problem 4: problem with installed package kernel-core-4.18.0-408.el8.x86_64
- package nvidia-driver-NVML-3:470.161.03-1.el8.x86_64 requires nvidia-driver(x86-64) = 3:470.161.03, but none of the providers can be installed
Problem 5: problem with installed package kernel-core-4.18.0-365.el8.x86_64
- package nvidia-modprobe-3:470.161.03-1.el8.x86_64 requires nvidia-driver(x86-64) = 3:470.161.03, but none of the providers can be installed
Problem 6: problem with installed package kernel-core-4.18.0-348.7.1.el8_5.x86_64
- package nvidia-settings-3:470.161.03-1.el8.x86_64 requires nvidia-driver(x86-64) = 3:470.161.03, but none of the providers can be installed
Problem 7: problem with installed package kernel-4.18.0-408.el8.x86_64
- package nvidia-xconfig-3:470.161.03-1.el8.x86_64 requires nvidia-driver(x86-64) = 3:470.161.03, but none of the providers can be installed
(try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
$ sudo dnf install cuda-11-4
Last metadata expiration check: 0:09:48 ago on Fri 02 Dec 2022 02:31:16 PM CET.
Error:
Problem: package cuda-11-4-11.4.4-1.x86_64 requires cuda-runtime-11-4 >= 11.4.4, but none of the providers can be installed
- package cuda-runtime-11-4-11.4.4-1.x86_64 requires cuda-drivers >= 470.82.01, but none of the providers can be installed
- package xorg-x11-drv-nvidia-470xx-cuda-3:470.141.03-1.el8.x86_64 requires nvidia-persistenced(x86-64) >= 3:470.141.03, but none of the providers can be installed
- package xorg-x11-drv-nvidia-cuda-3:515.65.01-2.el8.x86_64 requires nvidia-persistenced(x86-64) = 3:515.65.01, but none of the providers can be installed
- package cuda-drivers-470.103.01-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-470.129.06-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-470.141.03-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-470.141.10-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-470.161.03-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-470.82.01-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-495.29.05-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-510.108.03-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-510.39.01-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-510.47.03-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-510.73.08-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-510.84-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-510.85.02-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-515.43.04-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-515.48.07-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-515.65.01-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-515.65.07-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-515.86.01-1.x86_64 is filtered out by modular filtering
- package cuda-drivers-520.61.05-1.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:470.141.03-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:470.141.10-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:470.161.03-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:495.29.05-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:510.108.03-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:510.39.01-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:510.47.03-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:510.73.08-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:510.84-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:510.85.02-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:515.43.04-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:515.48.07-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:515.65.01-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:515.65.07-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:515.86.01-1.el8.x86_64 is filtered out by modular filtering
- package nvidia-persistenced-3:520.61.05-1.el8.x86_64 is filtered out by modular filtering
The required kernel version 4.18.0-425
doesn’t seem to be available! Am I missing something?
