nvidia driver and nvcc conflict
Hi all,
I have an old HP MobileWorkstation with Nvidia Quadro FX880M gpu.
I have installed Xubuntu 16.04 with recommended Nvidia-340.104 driver.
If I try to install NVCC, the mandatory driver turn to Nvidia-390 and I have some problems with the system.
Which version of NVCC could i install to driver and nvcc that works fine?
Use a 340.xx driver. The latest CUDA version supporting that very old GPU is CUDA 6.5
Hi txbob,
thank you for your reply.
I tried to install 340.104 with Cuda 6.5 using this guide
https://www.phobic.no/2017/09/26/installing-cuda-6-5-on-ubuntu-16-04-with-nvidia-geforce-8800gt/
and this patch
for the kernel 4.13.
Now seem to be ok :)
Hi txbob,
I have another problem, when I compile an application I have the error:
nvcc fatal : Unsupported gpu architecture ‘compute_52’
In this topic:
you gave at the user a different version of CUDA toolkit with Support for GeForce GTX9xx GPUs.
Can you give me a custom version for my gpu, please?
Fabio
cuda toolkit 6.5 doesn’t support compute_52. That would be a maxwell generation GPU.
