On a Fedora 29 running 4.19.10-300.fc29.x86_64 w/ latest NVIDIA driver but w/o CUDA and ocl-icd installed, I see:
$ lspci -k |grep -iA 3 vga
1d:00.0 VGA compatible controller: NVIDIA Corporation GP106 [GeForce GTX 1060 6GB] (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 3282
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
$ clinfo | grep -i intel
X server found. dri2 connection failed!
DRM_IOCTL_I915_GEM_APERTURE failed: Invalid argument
Assuming 131072kB available aperture size.
May lead to reduced performance or incorrect rendering.
get chip id failed: -1 [22]
param: 4, val: 0
param: 4, val: 0
param: 4, val: 0
param: 4, val: 0
param: 4, val: 0
Platform Name Intel Gen OCL Driver
Platform Vendor Intel
Platform Extensions cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_khr_3d_image_writes cl_khr_image2d_from_buffer cl_khr_depth_images cl_khr_spir cl_khr_icd cl_intel_accelerator cl_intel_subgroups cl_intel_subgroups_short cl_khr_gl_sharing
Platform Extensions function suffix Intel
I do not know where opencl i.e. the installed ocl-icd package on an AM4 AMD Board gets the idea of Intel from. ethminer seems to turn in. Any ideas? Thanks!
