Hi everyone,
I’m building a custom debian live distribution which is running from RAM only. It has some access to the network share and some special packages. All this i did using the debirf package. Computers which running this live distro are diskless machines with the Tesla K20m GPU. Using the debirf which uses chroot (i guess) to access the created system I’m able to install the required packages i.e linux-headers, gcc-4.6, make, build-essential even also create the symbolic link for gcc-4.6 which is required for NVIDIA-Linux-x86_64-340.32.run. During the build i get this error
DKMS make.log for nvidia-current-340.32 for kernel 3.2.0-4-amd64 (x86_64)
Sat Nov 1 17:38:33 CET 2014
make: Entering directory `/var/lib/dkms/nvidia-current/340.32/build'
make KBUILD_VERBOSE=1 -C /lib/modules/3.2.0-4-amd64/build M=/var/lib/dkms/nvidi$
make[1]: Entering directory `/usr/src/linux-headers-3.2.0-4-amd64'
make -C /usr/src/linux-headers-3.2.0-4-amd64 \
KBUILD_SRC=/usr/src/linux-headers-3.2.0-4-common \
KBUILD_EXTMOD="/var/lib/dkms/nvidia-current/340.32/build" -f /usr/src/l$
modules
make: file.c:145: enter_file: Assertion `*name != '
make: Entering directory /var/lib/dkms/nvidia-current/340.32/build' make KBUILD_VERBOSE=1 -C /lib/modules/3.2.0-4-amd64/build M=/var/lib/dkms/nvidi$ make[1]: Entering directory
/usr/src/linux-headers-3.2.0-4-amd64’
KBUILD_EXTMOD=“/var/lib/dkms/nvidia-current/340.32/build” -f /usr/src/l$
modules
make: file.c:145: enter_file: Assertion *name != '\0'' failed. Aborted make[2]: *** [sub-make] Error 134 make[1]: *** [all] Error 2 make[1]: Leaving directory
make: *** [modules] Error 2
make: Leaving directory `/var/lib/dkms/nvidia-current/340.32/build’
'' failed.
Aborted
make[1]: Leaving directory `/usr/src/linux-headers-3.2.0-4-amd64'
make: Leaving directory `/var/lib/dkms/nvidia-current/340.32/build'
^^^Any ideas about this?^^^
nvidia-detect
No NVIDIA GPU detected.
nvidia-smi
Unable to determine the device handle for GPU 0000:83:00.0: Unknown Error
nvidia-debugdump -l
Found 1 NVIDIA devices
Error: nvmlDeviceGetHandleByIndex(): Unknown Error
FAILED to get details on GPU (0x0): Unknown Error
dmesg | grep NVRM
[ 2400.286037] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 340.32 Tue Aug 5 20:58:26 PDT 2014
[ 2405.568003] NVRM: RmInitAdapter failed! (0x26:0xffffffff:1218)
[ 2405.573892] NVRM: rm_init_adapter failed for device bearing minor number 0
[ 2405.580824] NVRM: nvidia_frontend_open: minor 0, module->open() failed, error -5
cat /proc/driver/nvidia/gpus/0000\:83\:00.0/information
Model: Tesla K20m
IRQ: 121
GPU UUID: GPU-????????-????-????-????-????????????
Video BIOS: ??.??.??.??.??
Bus Type: PCIe
DMA Size: 40 bits
DMA Mask: 0xffffffffff
Bus Location: 0000:83:00.0
Any ideas? Help?
