GPU Nvidia A2000 12 GB
CPU Ryzen 5600G (IGFX disabled)
The Nvidia Linux drivers (535 but it fails with all of them) block the maximum pixel clock at 165 Mhz.
If I change to the Noveau driver, it correctly detects higher frequencies, 1920 x 1080 75 Hz - 185.590000 MHz, which is what my monitor supports.
I followed other threads and came to the conclusion that the problem is here.
Xorg.log
[16.983] (–) NVIDIA(GPU-0): DFP-2: disconnected
[ 16.983] (–) NVIDIA(GPU-0): DFP-2: Internal DisplayPort
[ 16.983] (–) NVIDIA(GPU-0): DFP-2: 2670.0 MHz maximum pixel clock
[16,983] (–) NVIDIA(GPU-0):
[ 17.078] (–) NVIDIA(GPU-0): KIG 238 Monitor (DFP-3): connected
[ 17.078] (–) NVIDIA(GPU-0): KIG 238 Monitor (DFP-3): Internal TMDS
[ 17.079] (–) NVIDIA(GPU-0): KIG 238 Monitor (DFP-3): 165.0 MHz maximum pixel clock
Although the GPU has 4 display port connectors, the xorg.log shows 8, 4 display ports and 4 TMDS. If I connect the cable to other ports it always connects to the TMDS but there is no way to be detected as Display Port.
As the freq limit is only in TMDS I think it will work as noveau if the driver detect it as Display Port but I tried a lot of Xorg config with no success, always TMDS
The hardware
hwinfo.txt (624.2 KB)
Xorg.log
xorg.log (37.6 KB)
Monitor EDID (With noveau I can set DTD 6 1920x1080 75HZ but with nvidia driver I can`t)
monitorEDID.txt (5.4 KB)
Xorg.conf
xorg.conf.txt (1.2 KB)
I don´t know if it is a bug or can be fixed with a configuration.
PS: I tried cvt and xrandr --addmode but nothing worked. It`s because de port limit. I think if the driver could detect correctly as Display port instead of TMDS it will work as noveau
