My operating system is Ubuntu 16.04. My graphics card is NVIDIA GeForce GTX 960M. I recently installed CUDA 9.0 driver and toolkit. I successfully compiled and ran CUDA applications. However, upon reboot, the drivers seem to have disappeared, and it is like I never installed them.
The result of nvcc -v is
The program 'nvcc' is currently not installed. You can install it by typing:
sudo apt install nvidia-cuda-toolkit
cat /proc/driver/nvidia/version gets me
cat: /proc/driver/nvidia/version: No such file or directory
The directory indeed does not exist. dev/nvidia also has disappeared. My CUDA samples folder still exists though.
This is the second time this has happened, both times within a day or two of installing CUDA. Everything works fine, I can run applications, and poof it’s gone. I read some threads blaming updates for a similar problem, but I have automatic updates disabled.
Aight so I’ve (kind of) figured out the problem. The drivers disappear whenever I install any type of new software whatsoever, not just system updates. Getting adobe flash player will do it. I haven’t figured out any solution, other than disabling all updates and never installing any new software.
Got the same problem, and my system is Ubuntu 16.04LTS,After I installed nvidia-driver it worked well, But some days later it suddenly disappeared without warning. I don’t know why, So don’t know how to find it back. And when I installed again, when installing, it will tell me that nvidia-driver is exist in my system and ask me to remove it or not. But I can’t find it throuh the settings or command with ‘nvidia-smi’ in the terminal.
This just happened to me on Ubuntu 18.04, CUDA 10 and an Nvidia Quadro K5000. Worked well for weeks, now I just came into office, started the computer and it booted in low resolution. nvcc doesn’t work and the graphics driver seemingly just disappeared.
having auto-updates enabled on Ubuntu can break the driver install, if an update that is applied (usually when you reset or power-cycle the machine) affects the kernel configuration.
DKMS is designed to help in this situation, but it may or may not be installed or enabled in your configuration.
