NVIDIA-Linux-x86_64-550.142
WARNING: Unable to determine the path to install the libglvnd EGL vendor library config files. Check that you have pkg->Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
→ Searching for conflicting files:
→ done.
→ Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (550.142):
→ No NVIDIA modules detected in the initramfs.
→ The initramfs will not be rebuild.
executing: ‘/usr/sbin/ldconfig’…
executing: '/usr/sbin/depmod -a '…
executing: ‘/usr/bin/systemctl daemon-reload’…
→ done.
→ Driver file installation is complete.
WARNING: Unable to find a suitable destination to install 32-bit compatibility libraries. Your system may not be set up>-> Uninstalling the previous installation → done. → Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new mo>-> Registering the kernel modules with DKMS: → done. Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’… Found libglvnd libraries: libGLESv2.so.2 libGLESv1_CM.so.1 libOpenGL.so.0 libEGL.so.1 libGLX.so.0 libGL.so.1 Found non-libglvnd libraries: Missing libraries: libglvnd appears to be installed.
ERROR: Unable to load the ‘nvidia-drm’ kernel module.
→ Kernel messages: [ 101.110654] vmbr0: port 22(veth126i0) entered blocking state
[ 101.110661] vmbr0: port 22(veth126i0) entered forwarding state
[ 101.635742] audit: type=1400 audit(1735312911.669:65): apparmor=“STATUS” operation=“profile_load” profile="/usr/bin/>[ 102.573657] vmbr0: port 23(veth127i0) entered blocking state
[ 102.573663] vmbr0: port 23(veth127i0) entered disabled state
[ 102.573685] veth127i0: entered allmulticast mode
[ 102.573746] veth127i0: entered promiscuous mode
[ 102.646140] eth0: renamed from vethnXCyK3
[ 104.029170] vmbr0: port 23(veth127i0) entered blocking state
[ 104.029176] vmbr0: port 23(veth127i0) entered forwarding state
[ 192.916067] VFIO - User Level meta-driver version: 0.3
[ 193.036070] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 193.177360] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 193.180969] nvidia 0000:01:00.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[ 193.419659] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 550.142 Wed Dec 11 05:15:39 UTC 2024
[ 193.444105] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriti>[ 193.491791] nvidia-uvm: Loaded the UVM driver, major device number 509.
[ 193.497663] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 550.142 Wed Dec 11 04:55:>[ 193.500848] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 193.500853] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 193.507329] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 193.535591] nvidia-modeset: Unloading
[ 193.558734] nvidia-uvm: Unloaded the UVM driver.
[ 193.595645] nvidia-nvlink: Unregistered Nvlink Core, major device number 511
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details. You may find suggest>
Whats wrong?
