Problem on installing RTX3070 drivers ubuntu dual boot
I see that the GPU is properly connected on Windows, cant install the drivers on Ubuntu
cuda-installer.zip (610 Bytes)
nvidia-installer.zip (6.4 KB)
INFO]: gcc version: gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04)
[INFO]: Initializing menu
[INFO]: Setup complete
[INFO]: Components to install:
[INFO]: Driver
[INFO]: 510.39.01
[INFO]: Executing NVIDIA-Linux-x86_64-510.39.01.run --ui=none --no-questions --accept-license --disable-nouveau --no-cc-version-check --install-libglvnd 2>&1
[INFO]: Finished with code: 256
[ERROR]: Install of driver component failed.
[ERROR]: Install of 510.39.01 failed, quitting
→ done.
→ Kernel module compilation complete.
ERROR: Unable to load the kernel module ‘nvidia.ko’. This happens most frequently when this kernel module was built against the wrong or improperly configured kernel sources, with a version of gcc that differs from the one used to build the target kernel, or if another driver, such as nouveau, is present and prevents the NVIDIA kernel module from obtaining ownership of the NVIDIA device(s), or no NVIDIA device installed in this system is supported by this NVIDIA Linux graphics driver release.
Please see the log entries ‘Kernel module load error’ and ‘Kernel messages’ at the end of the file ‘/var/log/nvidia-installer.log’ for more information.
→ Kernel module load error: No such device
→ Kernel messages:
[ 96.759040] nvidia_uvm: Unknown symbol nvUvmInterfaceSessionDestroy (err -2)
[ 96.759043] nvidia_uvm: Unknown symbol nvUvmInterfaceDupMemory (err -2)
[ 96.759045] nvidia_uvm: Unknown symbol nvUvmInterfaceDeviceDestroy (err -2)
[ 96.759048] nvidia_uvm: Unknown symbol nvUvmInterfaceAddressSpaceCreate (err -2)
[ 96.759051] nvidia_uvm: Unknown symbol nvUvmInterfaceUnregisterGpu (err -2)
[ 96.759053] nvidia_uvm: Unknown symbol nvUvmInterfaceAddressSpaceDestroy (err -2)
[ 96.759056] nvidia_uvm: Unknown symbol nvUvmInterfaceRegisterUvmCallbacks (err -2)
[ 96.759059] nvidia_uvm: Unknown symbol nvUvmInterfacePmaPinPages (err -2)
[ 96.759062] nvidia_uvm: Unknown symbol nvUvmInterfaceChannelAllocate (err -2)
[ 96.759065] nvidia_uvm: Unknown symbol nvUvmInterfaceGetP2PCaps (err -2)
[ 96.759067] nvidia_uvm: Unknown symbol nvUvmInterfaceEnableAccessCntr (err -2)
[ 96.759072] nvidia_uvm: Unknown symbol nvUvmInterfacePmaUnregisterEvictionCallbacks (err -2)
[ 96.759075] nvidia_uvm: Unknown symbol nvUvmInterfaceDupAllocation (err -2)
[ 96.759078] nvidia_uvm: Unknown symbol nvUvmInterfacePmaAllocPages (err -2)
[ 96.759082] nvidia_uvm: Unknown symbol nvUvmInterfaceSessionCreate (err -2)
[ 1887.741780] nvidia-nvlink: Nvlink Core is being initialized, major device number 507
[ 1887.742330] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=none,decodes=none:owns=none
[ 1887.742347] NVRM: The NVIDIA GPU 0000:01:00.0
NVRM: (PCI ID: 10de:249d) installed in this system has
NVRM: fallen off the bus and is not responding to commands.
[ 1887.742385] nvidia: probe of 0000:01:00.0 failed with error -1
[ 1887.742396] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 1887.742396] NVRM: None of the NVIDIA devices were initialized.
[ 1887.742484] nvidia-nvlink: Unregistered the Nvlink Core, major device number 507
ERROR: Installation has failed. Please see the file ‘/var/log/nvidia-installer.log’ for details.
